ML-210
Rik Shaw | 31/05/2019 18:42:13 |
![]() 1494 forum posts 403 photos | Machined up a couple of cast iron piston rod glands for my latest engine today only to find when finished that the front end was running out with the back end. I needed to just flash two surfaces on each gland at one end to bring them back into true but the job was made easier with a new acquisition. A little while ago I bid and won at a local auction a lovely example of a Japanese made RECORD ML-210 lathe with accessories. This very well made and almost unused (by the look of it) lathe had since lived in a cupboard in the workshop waiting for its first job. Today it made its debut. The two castings needed to be held by a 1/16” wide ledge which was far too small for the 6” chuck on the big lathe to manage but ideal for the small and extremely accurate 3 jaw on the RECORD. I skimmed the offending run outs on both castings and checked how well the “midget” had performed – spot on as it turned out. Just to say thank you to my little blue friend I am going to make it a tiny auto feed gearbox but not before I have completed the two cylinder sets on the Tangye (I really do try to avoid being sidetracked but ---- well you know what its like.) Rik |
Nick Hulme | 31/05/2019 22:01:51 |
750 forum posts 37 photos | I have the Record powered milling column for one of those but no mounting bracket, I used to use it as a cross slide milling attachment on my Myford, it's well made. |
John Haine | 31/05/2019 22:18:46 |
5563 forum posts 322 photos | Aka the Toyo 210 lathe. Interesting write up on lathes.co.uk. I always wanted one, ended up with a Unimat 3. |
Martin Hamilton 1 | 31/05/2019 23:02:12 |
188 forum posts | The Record ML210 was also known as the Toyo, Sakai, Proxxon & finally Manix, all the same lathe. |
Hopper | 01/06/2019 00:58:56 |
![]() 7881 forum posts 397 photos | Unique looking chuck on it, looks like the same principle as a drill chuck with the exposed crown gear around the outside. Very different. |
Mick B1 | 01/06/2019 09:40:28 |
2444 forum posts 139 photos | I think I've seen small keyed chucks like that for sale on t'web. The ML210 looks like a Unimat 3 clone - anybody know if it uses the same M14x1 spindle nose thread? I'm interested 'cos I have a Sieg C0 - also a Unimat 3 clone - and the 3-jaw that comes with that is fiddly to use and no better than it should be for concentricity. An easier and more accurate chuck would be a worthwhile mod. |
Colin Heseltine | 01/06/2019 09:55:38 |
744 forum posts 375 photos | That chuck looks like the same one as Cowells supplied for the ME90 lathe. I have one on my Cowells lathe. Colin |
Martin Hamilton 1 | 01/06/2019 11:10:15 |
188 forum posts | There is a Toyo version of this lathe on Ebay at the moment for £380. |
Brian Oldford | 01/06/2019 16:58:28 |
![]() 686 forum posts 18 photos | Posted by Colin Heseltine on 01/06/2019 09:55:38:
That chuck looks like the same one as Cowells supplied for the ME90 lathe. I have one on my Cowells lathe. Colin Just one step above the lever scroll 3 jaw that my kit built Flexispeed Meteor II had about 50 years ago. |
