ST Governor
Philip Burley31/05/2019 16:08:06
198 forum posts
I have been making up a ST governor for a ST beam engine . The spring like belt supplied is far too long , Has anyone else found this ? or what else can be used as a belt ?
regards Phil
Steve Withnell31/05/2019 17:58:29
858 forum posts
215 photos
Posted by Philip Burley on 31/05/2019 16:08:06:
regards Phil
I have one of those belts, but never used it. I've assumed it joins just like a Meccano belt where one end is a tight spiral that you 'screw' into the open end. It must be joined in some way?
Steve
JasonB31/05/2019 18:45:57
Just as Phil says one end spirals down to a smaller size that just twists into the open end. Chop a bit off teh full size open end and keep doing that until you get the length you need.
Just took the one off mine and it is 236mm end to end, think they are 300mm as supplied
Philip Burley31/05/2019 18:56:32
198 forum posts
yes Steve your quite right ., now I look more closely I have found an end . Thanks for the help
regards
Ian S C01/06/2019 14:54:33
7468 forum posts
230 photos
Oil seals, these have a similar spring 'belt', either get one or two from old seals, or get one the right size from a bearing supplier, they can be joined to make longer belts.
On the ST S9 I rebuilt I used a small square section rubber belt from a tape recorder(video/ audio can't remember), round belt just as good, just don't try a rubber band.
Ian S C
