Andrew Tinsley | 25/05/2019 17:18:38 |
1817 forum posts 2 photos | Does anyone know if Arrand boring heads have replaceable arbours? If so does anyone know if they have a common thread? Regards, Andrew. |
Brian Wood | 25/05/2019 18:27:35 |
2742 forum posts 39 photos | Hello Andrew, Yes, they do. The thread is 16 mm x 1.5 right hand Regards Brian |
Andrew Tinsley | 25/05/2019 20:17:56 |
1817 forum posts 2 photos | Thanks very much Brian! I thought someone would know. Regards, Andrew. |
SteveI | 25/05/2019 20:36:39 |
248 forum posts 22 photos | Hi,
the 3” head uses M14x1 the 4.5” and 5.25” use 16mm x 1.5mm, the shanks are the same as their fly cutters. the 6” I don’t know. the 6.5”, 8” boring and facing and 10.5” all use the same shanks but these are held on by a register and 4 shcs.
steve |
ronan walsh | 25/05/2019 22:00:36 |
546 forum posts 32 photos | Are Arrand boring heads still made ? I was looking for one last year and wanted an arrand, could not see much online about them. Bought an American made head instead and its good. Most of the asian made heads i have used seem to use a mystery measuring system on the dial. |
Andrew Tinsley | 25/05/2019 22:07:50 |
1817 forum posts 2 photos | Thanks Steve, I might have expected that it was more complicated! Andrew. |
Neil Wyatt | 25/05/2019 23:08:54 |
![]() 19226 forum posts 749 photos 86 articles | Posted by ronan walsh on 25/05/2019 22:00:36:
Are Arrand boring heads still made ? I was looking for one last year and wanted an arrand, could not see much online about them. Bought an American made head instead and its good. Most of the asian made heads i have used seem to use a mystery measuring system on the dial. I recall that it was essentially a one-man operation. He tried to sell the business when he retired but I don't think it continued. I may be wrong. Neil |
Michael Gilligan | 25/05/2019 23:41:40 |
![]() 23121 forum posts 1360 photos | It may be worth trying a 'phone call see this thread: **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=94955 MichaelG. |
Brian Wood | 26/05/2019 09:52:09 |
2742 forum posts 39 photos | Hello Andrew and Steve, Just to complete the list, my boring head is 3.25 inches and the arbour on that is interchangeable with that of the fly cutter bought at the same time. Thank you Michael G for snuffing out a hopefully live phone number to this excellent company, I am another fully satisfied user for >25 years Brian |
SteveI | 26/05/2019 15:11:41 |
248 forum posts 22 photos | Hi, I should have been clear about the sizes; those are the names that Arrand gave the different models. Based around the maximum bore using a side tool. From the catalogue the outside diameters of the heads are: the 3” head 1.3/8” or 35mm the 4.5” 1.3/4” or 44mm The 5.25” 2.1/8” or 54mm the 6” 2.1/2” or 63mm the 6.5” 2.3/4” or 70mm 8” boring and facing 3.1/2” or 89mm 10.5” 4” or 102mm
The catalogue I have does not mention a 3.25” head.
AFAIK Arrand does not manufacture any more but still trades selling from stock. I purchased my 3” head a few weeks ago direct from Arrand.I think rotagrip have some of the heads in stock according to their website.
steve |
Colin Heseltine | 13/11/2022 18:38:18 |
744 forum posts 375 photos | Today I visited the Clock Fair at Midland Motorcycle Museum. Whilst there I managed to pick up a brand new, still in the box, Arrand 4 1/2" boring head. It is not fitted with an arbor. I am trying to work out what thread it is. This post implies they are M16x1.5. This one certainly is not. The box is marked Imp (I guess for Imperial) and I assume this is for the graduation scale. It would appear to be 5/8" but not sure what TPI. Does anyone have any other ideas. I would like to fit it to an R8 arbor for use on the big mill. Thanks, Colin |
JasonB | 13/11/2022 18:43:02 |
![]() 25215 forum posts 3105 photos 1 articles | What makes you feel it is 5/8" rather than 16mm as there is 0nly 0.1mm difference between the two which would be hard to measure. |
Colin Heseltine | 13/11/2022 18:45:34 |
744 forum posts 375 photos | Cannot get a M16 x 1.5 tap to thread in. It struggles to fit into the spigot bore. |
DC31k | 13/11/2022 18:56:01 |
1186 forum posts 11 photos | Posted by Colin Heseltine on 13/11/2022 18:45:34:
Cannot get a M16 x 1.5 tap to thread in. It struggles to fit into the spigot bore. Screw a 5/8 dia. piece of wooden dowel into it. The threads will imprint on the wood and then you can measure pitch or tpi with a thread gauge. |
Colin Heseltine | 13/11/2022 19:07:00 |
744 forum posts 375 photos | Just had another play with it. Managed to find a new No.2 Second M16x1.5 tap and this did eventually thread in. There is a tommy bar hole and also a small threaded hole which both break into the thread before the thread has completed two turns. The bottom tap I had tried did not want to go past this point. I was being too gently. The number 2 tap has left a good witness mark in the spigot bore but got past the break in points and then threaded in nicely. Just need to put M16x1.5 thread on an R8 arbor now. Thanks Colin |
Colin Heseltine | 13/11/2022 19:17:49 |
744 forum posts 375 photos | DC31k, That's an idea I'd not thought of. Must remember for future. Colin |
JasonB | 13/11/2022 19:17:57 |
![]() 25215 forum posts 3105 photos 1 articles | ARC sell them if you don't want to make one |
Colin Heseltine | 13/11/2022 19:22:34 |
744 forum posts 375 photos | Jason, Thanks for that. At £9.58 plus postage its not worth switching the lathe on. One arbor just ordered. Thank you,
Halton Tank | 14/11/2022 18:26:24 |
![]() 98 forum posts 56 photos | Arrand Boring heeads are available at Rotagrip (at least their website says so). See Rotagrip Boring Heads Regards Luigi
