Swarf, Mostly! | 10/05/2019 11:17:47 |
753 forum posts 80 photos | Hi there,all, I've recently had a gentle disagreement with someone about the diameter of the through drilling in the mandrel of the Myford ML7 lathe (i.e. the back end). Well, not so much about the diameter as about it's consistency, lathe to lathe. This dimension is of interest in connection with mandrel handles or depth stops and, more loosely, with draw-bars or bumper bars. The published specification for the ML7 states that the through drilling is 19/32". (The same figure is given for the Super Seven. ) Please note, I'm not 'talking' here about 'big bore' or similar machines. Please may I use this thread to take a 'straw poll' from ML7 owning members, requesting them to post the size of the through drilling of their ML7 mandrel, together with their machine serial number? Thanks and best regards, Swarf, Mostly! |
Lambton | 10/05/2019 11:39:36 |
![]() 694 forum posts 2 photos | Swarf, I have a standard bore Super 7. I have never actually measure the bore as I already know the answer - Not big enough! Eric |
Grindstone Cowboy | 10/05/2019 11:47:11 |
1160 forum posts 73 photos | 0.595" on serial number K14593, which is pretty close to 19/32" (well, by my standards anyway I'll be able to measure another a bit later. Rob |
Grindstone Cowboy | 10/05/2019 14:55:17 |
1160 forum posts 73 photos | 0.590" on serial number K24217. This one was probably measured more accurately than the first as access was easier. Rob |
Brian Wood | 10/05/2019 17:22:18 |
2742 forum posts 39 photos | 0,630 inches (16 mm) on serial number KR 151488. Mine is the ML7R which has the S7 headstock and spindle Brian Edited By Brian Wood on 10/05/2019 17:23:27 |
Richard S2 | 10/05/2019 17:52:01 |
![]() 237 forum posts 135 photos | 19/32" on my ML7 ......K5711. |
Michael Gilligan | 10/05/2019 19:27:29 |
![]() 23121 forum posts 1360 photos | It's difficult for me to access the machine at the moment, so I used items from the socket-set as convenient plug gauges ... and made an interesting discovery: The bore is not parallel. Diameter 0.624" enters the bore at the tail, but only by about 1/2" Diameter 0.619" goes much further, but will not enter at the nose. Diameter 0.579" passes comfortably through. Sorry, I didn't have anything exactly 19/32" [0.59375"] diameter to hand. ML7R Ser. No. KR136508 MichaelG. |
Michael Gilligan | 11/05/2019 13:05:11 |
![]() 23121 forum posts 1360 photos | < bump > ... surely there must be more users around |
mgnbuk | 11/05/2019 13:11:43 |
1394 forum posts 103 photos | 0.630" from a quick digital caliper measurement on my mid-60s Super 7 (can't easily get to see the serial number). Nigel B |
Brian Wood | 11/05/2019 13:32:15 |
2742 forum posts 39 photos | mgnbuk, How can you miss it Nigel? It's on the front shear vertical face, right beside the gap and in the easiest position imaginable. Brian |
mgnbuk | 11/05/2019 15:11:51 |
1394 forum posts 103 photos | How can you miss it Nigel? It's on the front shear vertical face Not on mine, Brian. Its at the back of the rear shear at the tailstock end of the bed and my lathe is close to a wall, so I can't get my head in the space far enough away to be able to focus on it (one of the "pleasures" of getting old ! ) . However, use of the camera in my phone has allowed me to see the number remotely , which is SK78311. Nigel B |
AJW | 11/05/2019 16:02:28 |
![]() 388 forum posts 137 photos | I've got 0.594 on a ML7 s/n K16170 and seems pretty parallel.
Alan Edited By AJW on 11/05/2019 16:03:14 |
Brian Wood | 11/05/2019 18:33:07 |
2742 forum posts 39 photos | mgnbuk, My apologies Nigel; mine is clearly a much younger model. Sorry to doubt you, especially as you found an ingenious solution to read it. Regards Brian |
Mike Poole | 09/08/2019 23:34:23 |
![]() 3676 forum posts 82 photos | I have never measured mine fnarr fnarr but whatever the size if my work will go through then happy days and if it won’t the out comes the steady. Mike |
John Olsen | 11/08/2019 04:35:25 |
1294 forum posts 108 photos 1 articles | Mine, of about 1953 vintage, measures at .590 inch. That's using a digital caliper, maybe + or _ a thou or so on that. It is of course too small, but anything will always end up too small because the jobs expand to exceed the capacity of the lathe. John |
Don Cox | 12/08/2019 14:25:08 |
63 forum posts | I have an ML 7 of (I think) 1949 vintage, no. K3475, it has a through bore of 0.58" although I reckon there may be some bits of swarf jammed in there which might have reduced it a bit. I also have an S7 mk2 of (also, I think) 1963 vintage, no. SK62224 which has a through bore of 0.63" Don |
ega | 12/08/2019 16:20:57 |
2805 forum posts 219 photos | My 1964(?) S7 SK 66266 will just pass 0.620" from the tail for most of its length. This is the major diameter of my J A Radford stop bar. His was 0.621" and was "perfectly free in the mandrel except for the end nearest the chuck which was reduced to 0.580" ". Edited By ega on 12/08/2019 16:23:08 |
Malc | 12/08/2019 17:45:35 |
113 forum posts 6 photos | Mine is 0.625”, serial No. K 76235. |
Kenneth Deighton | 12/08/2019 19:56:55 |
69 forum posts | I think that the main question is how do you increase the bore ? Ken. |
Mike Poole | 12/08/2019 21:32:03 |
![]() 3676 forum posts 82 photos | The 2 morse taper in the nose of the spindle would be compromised if the spindle is bored larger and there is not too much meat on the other end. The bore increase would be small which is probably why Myford did a major redesign when they made the big bore version. Mike |
