Martin King 2 | 11/04/2019 10:50:38 |
![]() 1129 forum posts 1 photos | Hi All, just back from a buying trip in France, we hit about 3 large vide greniers in one day so pretty knackered but found some great items. This one has got me stumped: Very well made as two sliding wedge shaped pieces with locking bolt which is possibly a replacement. My only thought is that it might be a leatherworking expander tool for shoe or boot work but not at all sure? Any thoughts welcome! Cheers, Martin |
mark costello 1 | 11/04/2019 18:30:43 |
![]() 800 forum posts 16 photos | A cleverly designed frustration tool used to baffle British Men and Yanks at the same time. |
Watford | 11/04/2019 18:50:28 |
![]() 142 forum posts 11 photos | Would it fit together with both boat shaped pieces on the same side of the slide? I still don't know what it would be though
Mike |
Jon Lawes | 11/04/2019 19:16:09 |
![]() 1078 forum posts | Do they fit together the other way? |
Martin King 2 | 11/04/2019 20:16:52 |
![]() 1129 forum posts 1 photos | Only goes together one way round martin |
Jon Lawes | 11/04/2019 20:22:21 |
![]() 1078 forum posts | I wonder if the bolt previously was a larger one with a spring under it? |
Speedy Builder5 | 11/04/2019 20:34:24 |
2878 forum posts 248 photos | Ah! That would be the 10cm Froggle guide. |
Martin King 2 | 11/04/2019 20:47:20 |
![]() 1129 forum posts 1 photos | I wondered if there might have been a very large spring between the two halves so that they could be squashed together somehow and exert a spreading force on leather perhaps? martin |
Nimble | 11/04/2019 21:56:54 |
![]() 66 forum posts 6 photos | Messieurs, Can you not see it is for keeping zee beret in shape! Neil |
Jeff Dayman | 11/04/2019 22:12:58 |
2356 forum posts 47 photos | It may be for a tire machine, to spread old-style narrow tires or maybe guide them onto rims. I remember vaguely an attachment shaped like this on my grandfather's old tire machine which dated from the 1930's. Or, could be some sort of guide to ease electrical cable or soft pipe into channels of some kind.
Brian Sweeting | 11/04/2019 22:15:00 |
453 forum posts 1 photos | Are we unique I wonder? We travel around and buy odd bits of metal that have no obvious use to us but whose sole purpose is to start a debate down the pub on a quiet afternoon. |
Ian P | 11/04/2019 23:10:13 |
![]() 2747 forum posts 123 photos | Could these be two separate items just held together with a bolt for the sake of it? I cannot tell from the picture if one has a tongue and the other a groove but otherwise they do look something like the long handle lever thing that tyre fitters use and the semicircular notch looks ideal for a bar handle to sit in. Ian P |
Martin King 2 | 12/04/2019 07:11:43 |
![]() 1129 forum posts 1 photos | Ian P, they do look like they are meant to fit together and slide over each other. I get what people are saying about tyres, there is a part on a tyre machine that guides the rim or tyre bead but only a single part not 2? Brian S, possibly you are correct Martin |
Brian Wood | 12/04/2019 08:54:27 |
2742 forum posts 39 photos | I'm with you Martin, that looks very much like a shoe expander to broaden ze leather for spreading feet. Brian |
Jeff Dayman | 12/04/2019 08:56:48 |
2356 forum posts 47 photos | Martin you are thinking newer style tire machines - I'm thinking ones from 1930's - they were very different and there were many styles and gimmicks. |
Nicholas Farr | 12/04/2019 10:02:47 |
![]() 3988 forum posts 1799 photos | Hi, I can't imagine it to be a shoe expander. The only shoe expanders I've ever seen, or pictures of, look like these **LINK** Regards Nick. |
SillyOldDuffer | 12/04/2019 11:32:04 |
10668 forum posts 2415 photos | Could the projections ringed in red be feet? Possibly the tool sits on the edge of a table with the 'anvil' points facing up. My guess is it's for taking the dents out of old-fashioned metal hub caps, and the 'feet' are gripped in a vice. Dave |
Georgineer | 12/04/2019 11:33:43 |
652 forum posts 33 photos | It's a grostling iron. George |
IanT | 12/04/2019 12:21:57 |
2147 forum posts 222 photos | That's correct George, although to be absolutely accurate - the French refer to them as "Le Fer Grostling" They should be heated to red-hot before insertion. IanT
Hopper | 12/04/2019 12:27:14 |
![]() 7881 forum posts 397 photos | So the projections circled in red would be grostling snibs then. |
