Construction material
MICHAEL Moore 1 | 08/04/2019 15:32:49 |
12 forum posts | Hi Can anyone tell me if inconel 740 steel can be used to build a boiler for a 5ich gauge loco
Thor 🇳🇴 | 08/04/2019 15:41:40 |
![]() 1766 forum posts 46 photos | Most states in Australia accepts model boilers made from "Duplex" stainless steel. Have you contacted your club boiler inspector about using Inconel steel, you may have trouble getting it certified. Thor |
Paul Kemp | 08/04/2019 19:41:52 |
798 forum posts 27 photos | Not in England you can't if you want to go the club testing route as the code specifically precludes stainless as a generic and I imagine NI is the same, not sure about the South though. You might be OK with a commercial test and a commercial insurer as long as you can do the numbers and get a design approved. Could be complicated and expensive though! I can see the logic precluding stainless as a material given its propensity for cracking and sudden failure but other places in the world as well as Europe allow it, maybe we are stuck in the dark ages. Paul. |
DrDave | 08/04/2019 20:10:46 |
264 forum posts 52 photos | With a maximum Fe content of 3%, Inconel 740 is hardly a steel! It is designed for the superheater section of a coal-fired boiler in a power station, but does its cost not make it less attractive, even given the probable difficulties in trying to get a boiler certificate. |
Boiler Bri | 08/04/2019 20:27:44 |
![]() 856 forum posts 212 photos | Has anyone read the code that the Australians use for stainless steel boilers?
Bri |
Thor 🇳🇴 | 09/04/2019 06:25:59 |
![]() 1766 forum posts 46 photos | Posted by Boiler Bri on 08/04/2019 20:27:44:
Has anyone read the code that the Australians use for stainless steel boilers? Bri I only found these on the Internet, seems you have to buy a copy, others may be able to find it. Thor |
Martin Johnson 1 | 09/04/2019 08:30:06 |
320 forum posts 1 photos | " You might be OK with a commercial test and a commercial insurer as long as you can do the numbers and get a design approved. Could be complicated and expensive though! " I have just completed that route for a conventional steel vertical firetube boiler. 18 pages of calculations, many pages of risk assessments, installation and operation instructions etc. etc. later, plus over £1500 lighter in the wallet department just for design approval and independant testing. I cover some of this in an article coming up in the next issue of EIM. In short, that sort of money will buy you a hell of a lot of copper and silver solder. Martin |
Simon Collier | 09/04/2019 09:28:45 |
![]() 525 forum posts 65 photos | There has been a concerted effort by some senior people to have the Australian codes put on the net for all, but the AMBSC reckons they can't afford to forego the money from selling them. There was an article in AME on the testing of a Duplex boiler, for a 7-1/4 Darjeeling B, a few years back. |
Samsaranda | 09/04/2019 10:06:51 |
![]() 1688 forum posts 16 photos | I would imagine that machining the inconel would be challenging, we used to machine it at one company I worked for and I know that inconel castings were a real pain. We were using machining centres that could use the correct speeds and feeds and had plenty of power. Dave W |
