Here is a list of all the postings MICHAEL Moore 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Emco Compact 5 cnc |
25/09/2023 21:32:07 |
Unfortunately the lathe has taken a battering in the school. A lot ripped out in the back panel andother missing bits.
25/09/2023 18:14:01 |
Hi from Ireland. I am retrofitting an old ex school Emco compact 5 CNC lathe. It has the original 3 jaw Emco 80mm chuck but with only 1 jaw. Can anyone help me source replacement jaws and spindle motor and vfd. Also can anyone recommend a replacement half horse 3 phase spindle motor and vfd. I have the new controls and steppers fitted too. Thanks in advance
Michael |
Thread: Mini bench saw |
22/03/2020 21:36:38 |
Thanks for your advice. Looking for a set of plans to build a 3 in 1 metal worker and purchasing a band saw. |
22/03/2020 14:40:31 |
Hi all, I hope you are keeping well. Can anyone advice on purchasing a small bench saw that can cut brass and aluminium for model making. The blade capacity should be 4 inch or thereabouts. Also is there tooling for small high speed milling and cutting below a 2mm cutter , manual and small cnc units. I have a Myford Super 7 with gearbox and I fittedr an Allendale DRO and I also have a manual Quantum Mill. Any help would be greatly appreciated. Thanks in advance Michael
Thread: Steam Boiler |
08/04/2019 15:32:49 |
Hi Can anyone tell me if inconel 740 steel can be used to build a boiler for a 5ich gauge loco
Thread: Carbide tip holders |
18/12/2017 10:29:21 |
Hi, Can anyone recommend a set of carbide tipped holders plus inserts for a Myford Super 7 and an ideal Quick Change Toolpost to hold said tip holders. Thanks in advance Michael
Edited By JasonB on 18/12/2017 10:38:16 |
Thread: getting a mill over to Ireland |
09/07/2017 19:52:07 |
Michael from Kildare here. I bought a Optimum bf 20l mill from Millenium machinery in Athlone , €2000 , and it is a great little mill , I also purchased the Allendale Dro kit for a mill although €500 + it is worth it I also have a Myford Super 7 with the Allendale Dro and a drive converter which is ideal for the hobby I buy in all types of machinery from the UK and a pallet from inside Manchester/Birmingham/Bristol is about €200 The other side of that line is twice that |
Thread: Boiler Welding |
29/06/2017 18:07:47 |
Looks likes Tig walking the cup.... Nice work |
Thread: Emco compact 5 cnc lathe with Welturn |
26/02/2017 20:56:30 |
All the electrics at the back are torn out and damaged and the front buttons panel is in a bad way. I was hoping to fit new steppers through an appropriate motherboard and power supply through a suitable pc / laptop I hope this is possible |
26/02/2017 17:00:01 |
Thanks for the reply. Unfortunately due to a lot of damage and missing parts for the Emco I need a lot of new bits so I want to do it as a cnc. Any help sourcing the parts is greatly appreciated. Thanks |
24/02/2017 12:05:22 |
Hi all, Michael Moore from Ireland here. I have an x school Emco Compact 5 that I am looking to upgrade to a cnc jobby. I just started following an American site who have done this http://www.cnczone.com/forums/emco-cnc-machines/108826-cnc-machinist-posts.html https://en.industryarena.com/forum/build-thread-upgrading-emco-compact-5-cnc-current-technology--108826-2.html Has anyone attempted this sucessfully and can you give me any advice please. Thanks in advance Michael |
Thread: Locomotive Modelling in Ireland |
29/12/2016 13:08:58 |
Hi all, Michael from Ireland here I need to sharpen end mills and drill bits as I work a lot in stainless Whats my best option. I have about £500 to spend |
