Dave Springate | 03/03/2019 22:50:36 |
![]() 56 forum posts 121 photos | Hi all just a quickie, are the T slots on a ML7 the same size as on an ML 10 ? |
Chris Trice | 04/03/2019 01:22:22 |
![]() 1376 forum posts 10 photos | Yes and the Super 7.
Dave Springate | 04/03/2019 07:21:13 |
![]() 56 forum posts 121 photos | Thanks Chris |
Steve Neighbour | 08/03/2021 18:39:05 |
135 forum posts 1 photos | I have always found it annoying how much oily swarf clogs up the T slops on my Lathe cross slides, which isn't always easy to brush out I found someone who can 3D print 'in-fill' strips at a very reasonable cost to your own accurate profile drawing and lengths As an example I ordered 3 lengths to suit my WM250 cross slide to my own bespoke drawing, he created the STL file as needed and made them for £10 inc postage which I thought wasn't excessive. If anyone is interested please PM me for the contact details Thanks, Steve Edited By Steve Neighbour on 08/03/2021 18:39:20 |
Steviegtr | 08/03/2021 18:56:19 |
![]() 2668 forum posts 352 photos | There are a few sellers on ebay doing them in most pretty colours or grey. From memory for the Super 7 etc £11 for a set of 5. Steve. |
not done it yet | 08/03/2021 19:18:41 |
7517 forum posts 20 photos | annoying For a mill, I lay a thin sheet of material either side of the vise or under the item, if clamped to the bed. Little need for slot cleaning, if placed at the right position? Mill or turn dry? Vacuum it out before it becomes a solid morass? Lathe cross slides are not that wide? Make a suitable T shaped scraper to clean them out - brushing will likely spread it all over the bed. They say you can’t make an omelette without breaking an egg; getting chips is all part of machining. |
Martin Kyte | 08/03/2021 22:12:11 |
![]() 3445 forum posts 62 photos | I made T slot fillers for the Myford, only mine are mahogany. regards Martin Edited By Martin Kyte on 08/03/2021 22:13:06 |
Nigel Graham 2 | 08/03/2021 22:24:32 |
3293 forum posts 112 photos | Mahogany, eh? There's posh! I cut a T-shaped scraper for the mill, from a bit of 3mm PVC sheet. Otherwise I just use brushes. |
Steviegtr | 08/03/2021 22:25:29 |
![]() 2668 forum posts 352 photos | Just been making these tonight. Ready to paint tomorrow. Steve. |
John Baron | 09/03/2021 07:26:42 |
![]() 520 forum posts 194 photos | Hi Stevei, Very nice protectors for the mill table ! I'm just about to make some new ones for mine ! I've just fitted a set of scales for the DRO on mine and am doing some servicing whilst I'm at it. Surprising what you find when you start stripping a Chinese mill to bits. I'm about to investigate sorting out the quill bearings ! They feel fine in the machine, but quite lumpy with the quill out and turned by hand.
Edited By John Baron on 09/03/2021 07:28:48 |
Hopper | 09/03/2021 08:06:53 |
![]() 7881 forum posts 397 photos | Posted by John Baron on 09/03/2021 07:26:42:
Edited By John Baron on 09/03/2021 07:28:48 Get some good SKF or Timkens. All bearings are NOT created equal! You might as well do it while you have it apart. Bearings are cheap enough, even the top quality ones. |
Steviegtr | 09/03/2021 15:39:48 |
![]() 2668 forum posts 352 photos | +1 on Hopper's comment. I got my lad one of those mini motorcycles, many years ago. The wheel bearings packed in pretty quick. When stripped, the bearing could be filed they were so soft. Good thing was they were all available in standard size Fag bearings. Steve. |
not done it yet | 09/03/2021 15:55:22 |
7517 forum posts 20 photos | Ha ha. Nothing wrong with chinese bearings. Everything coming out of China is quality. Of some description.... Just look at the quality of THESE bearings.😀 https://youtu.be/AvF5ETQfm8o |
Steviegtr | 09/03/2021 16:05:27 |
![]() 2668 forum posts 352 photos | Posted by not done it yet on 09/03/2021 15:55:22:
Ha ha. Nothing wrong with chinese bearings. Everything coming out of China is quality. Of some description.... Just look at the quality of THESE bearings.😀 https://youtu.be/AvF5ETQfm8o Yep. Enough said. Steve. |
Howard Lewis | 09/03/2021 16:21:38 |
7227 forum posts 21 photos | One way of cleaning T slots is to make up a tool from sheet steel, where the bottom end is a close fit in the the T slot. Moving the tool along the slot pushes the swarf ahead of the tool and out of the slot. Howard |
Adrian 2 | 09/03/2021 17:04:34 |
104 forum posts 19 photos | This cover works a treat , just lifts off. I forget to replace it sometimes then really appreciate what a good job it does. |
Matt Harrington | 09/03/2021 17:11:41 |
![]() 212 forum posts 16 photos | Anyone tried flexible magnetic sheet. I have some somewhere and was thinking of trying this but have never got around to it..... Matt |
Grindstone Cowboy | 09/03/2021 17:35:54 |
1160 forum posts 73 photos | I try and avoid anything magnetic around the lathe (and mill too, if I had one). Makes ferrous debris that much harder to shift. Rob Edit - have a friend whose Super 7 has wooden T-slot fillers. Edited By Grindstone Cowboy on 09/03/2021 17:36:52 |
Steveg | 14/03/2021 08:27:27 |
30 forum posts | I’ve just ordered a set of these to keep the slots clean. |
Oven Man | 14/03/2021 10:18:25 |
![]() 204 forum posts 37 photos | There is a really nice design for Super 7 T slot closers on Thingiverse. It was one of the first things I made when I got my 3D printer. At first sight I thought there was a fault with the printer because it was producing a slight bump on the side. When I looked carefully at the model I discovered it was a deliberate bump to hold it in place. So the part slides in easily and the bump engages to hold it tight and stop slipping. Works brilliantly. Peter |
