Looking to source affordable screws
Mark Whelan | 27/02/2019 20:59:55 |
11 forum posts | Hey all,
I'm after shearing off two screws in the tailstock of my myford m type, which I think are 3/16 24 bsw I've drilled them out and now I need to replace them. There's a few sellers on eBay but the want between 10-20 pounds shipping to Ireland for 5 screws!
Anyone recommend somewhere more reasonable? |
Speedy Builder5 | 27/02/2019 21:18:26 |
2878 forum posts 248 photos | Why not have a go at making them. You would feel great when you have done them. Not too difficult. Bobh |
Former Member | 27/02/2019 21:35:42 |
[This posting has been removed] | |
peak4 | 27/02/2019 21:46:27 |
![]() 2207 forum posts 210 photos | I can do you 1/2" and 3/4" mild steel roundheads (I think, I'll have to check up)
Bill
JohnF | 27/02/2019 23:12:25 |
![]() 1243 forum posts 202 photos | Mark, they may well be 2BA but look at your PM's John |
Hopper | 27/02/2019 23:28:04 |
![]() 7881 forum posts 397 photos | I buy BSW screws, nuts and bolts from my local hardware store. Although Australia went metric 40 years ago, the building trade still seems to use the old imperial stuff for some reason. They are just labelled as 1/4" x 1" screw etc. No idea about Ireland though! |
duncan webster | 28/02/2019 10:04:56 |
5307 forum posts 83 photos | 3/16 bsf is nearly the same as 2BA, but 3/16 bsw is much coarser. If you are sure you want bsw then try the trusty e-bay f:1&frcectupt=true">https://www.ebay.co.uk/itm/1-8-3-16-1-4-BSW-Whitworth-High-Tensile-Cap-Head-Allen-Bolts-Socket-Screws/271903549676?hash=item3f4eb6e8ec:m:mQSWuri_vZQT8SoOxDhjDig:rk:1 |
vintage engineer | 28/02/2019 10:07:18 |
![]() 293 forum posts 1 photos | Meccano screws.
Adam Mara | 28/02/2019 10:43:51 |
198 forum posts 1 photos | Loads of BSW machine screws at work, at least 25 years old ex B&Q! PM me if don't have any luck, I will be going into work on Monday to collect the rent, and can pinch a few and post them to you! |
Georgineer | 28/02/2019 11:50:49 |
652 forum posts 33 photos | Posted by vintage engineer on 28/02/2019 10:07:18:
Meccano screws.
That won't work. Meccano screws are 5/32" BSW. George |
Andrew Johnston | 28/02/2019 12:30:19 |
![]() 7061 forum posts 719 photos | I don't know what thread Myford used, but 3/16" BSW would be a poor choice. It's a small diameter rather coarse pitch thread, with the result that the slightest overtightening fractures the core. Been there, done that! Andrew |
Mark Whelan | 28/02/2019 13:22:35 |
11 forum posts | Hi Guys,
Thanks for all the tips and for the PM's offering to help. The 10-24 is probably easiest to try first, as I should have some lying around in work, if that doesn't work I'll try the next few options. I'll also try to remember to report back with some news hopefully. Mark
Howard Lewis | 28/02/2019 15:47:23 |
7227 forum posts 21 photos | These sound like the screws retaining the plates for the Handwheel. On a ML2 or ML4 they are likely to be 3/16 BSW (or maybe 3/16 BSF ? ) roundhead. Take up the kind offer already made a few posts ago; You only need two! Howard. |
