How many threads please
Former Member | 10/02/2019 18:47:30 |
1329 forum posts | [This posting has been removed] |
JasonB | 10/02/2019 19:19:13 |
![]() 25215 forum posts 3105 photos 1 articles | Thread sealant would be better than lock |
Howard Lewis | 10/02/2019 19:27:31 |
7227 forum posts 21 photos | Ideally you should aim for at least 1 D engagement, 1.5 D or 2 D would be even better. These are usual parameters for threaded components subjected to axial loads. In this case, going into 3 mm thick tube,,from the side, you don not seem to have much option and so must live with just less than 5/8 D. (0.118 / 0.1875) If the threads are axial, then aim for at 1 D engagement minimum. Since it is a lubricator, in situ, it is unlikely to suffer much stress so it will probably suffice. Don't overstress things by overtightening the locknut!. If possible, I would try to avoid making the threads a loose fit.. In any case, a slack fit will allow leakage. A sealant should be used, since you don't want steam or oil escaping Howard, . |
John Rudd | 10/02/2019 20:08:11 |
1479 forum posts 1 photos | sealant needs to be able to withstand steam temperature..... Edited By John Rudd on 10/02/2019 20:08:59 |
Paul Kemp | 10/02/2019 20:22:36 |
798 forum posts 27 photos | I am assuming you are screwing a male fitting on the lubricator into the side of a 3mm thick pipe? That beingnthencase you would be better off silver soldering a boss with a female thread onto the pipe. Paul. |
Tim Taylor 2 | 12/02/2019 16:04:58 |
70 forum posts 8 photos | Posted by John Rudd on 10/02/2019 20:08:11:
sealant needs to be able to withstand steam temperature..... Edited By John Rudd on 10/02/2019 20:08:59 This is an excellent point. I would suggest using one of the thread sealing compounds designed for steam use - they come in a paste compound that typically includes nickel and copper, and are non-hardening, making later removal easier. Tim |
not done it yet | 12/02/2019 19:51:30 |
7517 forum posts 20 photos | A couple of practical points, as I see it. One cannot just hang a lubricator on a pipe - better for the lubricator to be suppported and a vibration proof/flexible pipe arrangement to connect the two. Screwing in anything to a curved surface requires either a tapered thread or a boss (as per PK,) and sealing the connection with a washer (if a parallel thread). A curved surface would only support a locknut at two points. |
vintage engineer | 12/02/2019 20:07:12 |
![]() 293 forum posts 1 photos | The ideal is 1 1/2 times diameter
JasonB | 12/02/2019 20:15:12 |
![]() 25215 forum posts 3105 photos 1 articles | But do you ever see these lengths of thread on plumbing? Typical model nut and nipple probably less than 0.5D. Domestic compression fitting maybe only 0.25D and they are good for 7bar at 120degC at 15 & 22mm |
duncan webster | 12/02/2019 23:46:14 |
5307 forum posts 83 photos | All these rules for depth of thread are aimed at developing full strength, but you don't need anything like full strength on this application. Assuming 80 psi steam, you have 2.2 lbs force. The pitch diameter of the thread is near enough 11/64" and the thread length is 1/8" (again near enough), so the area of thread in shear is 11/64 * pi * 1/8 * 1/2 = 0.034 sq.in, so the shear stress is 65 psi, which is not a lot. Go for it, use sealant and don't over-tighten just for interest, a 1/4" bsw nut is only 0.2" thick, 0.8D, your 3mm is 0.63D Edited By duncan webster on 12/02/2019 23:50:39 |
