Hi from Birmingham
David Keil 118/01/2019 16:13:20
24 forum posts
7 photos
Hi
Very new to engineering of any sort. I am the proud owner of a Taig/Peatol lathe which I have messed around with for a couple of years.
Now is the time to do something serious, so have decided to build a skeleton clock. Have the John Parslow skeleton clock plans/booklet (slowly trying to understand the plans).
Have also just purchased a Colin Walton wheel cutting engine and yet to use it.
My first question is, has anyone got one with the instructions that they can copy for me. Really trying to work out how I can use it with my Taig.
Many thanks
Bazyle18/01/2019 23:30:48
6956 forum posts
229 photos
I had not heard of this wheel cutting device before and google only has a couple of pictures. Perhaps you can work out how to post a few rather clearer pictures of it to clarify it for us all.
Michael Gilligan19/01/2019 00:24:18
23121 forum posts
1360 photos
A couple of decent photos, and a basic description here: **LINK**
https://pennyfarthingtools.co.uk/wheel-and-pinion-cutting-attachment/2014/08/02/
Note: Malcolm J. Wild's book is excellent.
Michael Gilligan19/01/2019 01:19:53
23121 forum posts
1360 photos
Posted by David Keil 1 on 18/01/2019 16:13:20:
Sorry, Dave ... I just re-read your opening post
Do you have the device that I linked, or an actual stand-alone wheel cutting engine ?
MichaelG
David Keil 119/01/2019 09:28:55
24 forum posts
7 photos
The engine I have is I believe one designed by Colin Walton, some very slight differences from the one linked to.
I will be posting photo's shortly.
Having spent some time investigating the engine I now think I know how to operate it, quite simple really, but we will see.
Might be a bit heavy for the taig!
David Keil 119/01/2019 09:42:46
24 forum posts
7 photos
Ok photo's added in album, hope they are ok.
Any comments are welcome.
Russell Eberhardt19/01/2019 10:02:02
2785 forum posts
87 photos
Hi Dave
Welcome.
I built the John Parslow skeleton clock as my first clock making project. I finished it in 2013 and it has run well ever since although now it has started gaining about two minutes a week so it must be due for a service.
You can see some pictures taken during the construction in my album. If you have any questions just ask.
Russell
David Keil 119/01/2019 10:18:41
24 forum posts
7 photos
Hi Russell
Great photo's and very informative. am sure I will be asking several questions smiley.
First one is best way to turn silver steel for the arbors, my attempts so far are a failure!
Michael Gilligan19/01/2019 10:39:56
23121 forum posts
1360 photos
Dave,
Have a look, here: **LINK**
https://picclick.co.uk/Colin-walton-Wheel-and-pinion-cutting-attachment-153071656760.html
Then follow the link to ebay
The listing has ended, but image 4 of 5 is still visible ... it may help.
P.S. ... I have no idea why, but only three [of an advertised seven] images are currently visible in your Album
Edited By Michael Gilligan on 19/01/2019 10:41:58
Russell Eberhardt19/01/2019 11:45:34
2785 forum posts
87 photos
Posted by David Keil 1 on 19/01/2019 10:18:41:
Hi Russell
I can't tell you the best way but what I did was turn them held in an ER collet chuck using a very sharp HSS tool. Then polished starting with oiled 400 grit wet and dry and going through the grades down to 2000 grit. Finally used "Micro-Mesh" with water **LINK**
I cut thin strips of the abrasive sheets and glued them to lollipop sticks to help keep the polishing even. By clockmaking tradition the pivots should be burnished but I found that a good polished surface worked fine.
I don't know if you have a collet chuck for your lathe but you do need to ensure good centering.
Russell
David Keil 119/01/2019 11:50:24
24 forum posts
7 photos
Hi Michael
From what little I could see in that link, I believe that it may be the one that I have just purchased or at least one very similar. The info given has really confirmed my thoughts on how to set it up.
David Keil 119/01/2019 11:55:16
24 forum posts
7 photos
Russell
Thanks for the information, I think my problem with turning silver steel is due to my lack of ability in ensuring that the tool is sharp enough, I have been using an indexable tool.
Have just upgraded to er16 collets and must admit I am very impressed.
Russell Eberhardt19/01/2019 14:45:57
2785 forum posts
87 photos
Posted by David Keil 1 on 19/01/2019 11:55:16:Thanks for the information, I think my problem with turning silver steel is due to my lack of ability in ensuring that the tool is sharp enough, I have been using an indexable tool.
Yes, if you are using an indexable insert you will need to use one of the highly polished inserts that are intended for aluminium, they have a sharper cutting edge. The general purpose coated ones have a rounded edge to give them more strength but then need a deep cut to work well. They are also likely to deflect the work somewhat.
Russell
David Keil 119/01/2019 15:08:14
24 forum posts
7 photos
Russsell
Thanks for the info, I will and try and find a UK supplier.
Have just set the wheel cutter up an my Taig lathe, Had to do some small alterations but nothing severe and it seems to work well.
Next thing to get is a wheel cutter, maybe from bergeon, although a bit costly.
Russell Eberhardt19/01/2019 15:38:51
2785 forum posts
87 photos
These people sell Thorntons wheel and pinion cutters **LINK**
http://www.clock-works.clara.net/index.html
Not cheap but probably cheaper than bergeon.
Russell.
Neil Wyatt19/01/2019 20:35:47
19226 forum posts
749 photos
86 articles
Welcome to the forum Dave,
David Keil 119/01/2019 21:01:17
24 forum posts
7 photos
Thank you Neil
