Ian Usmar | 13/01/2019 17:58:39 |
71 forum posts 10 photos |
Bazyle | 13/01/2019 19:47:25 |
![]() 6956 forum posts 229 photos | The missing part is the 'backgear layshaft' which has two gears, one large one small. However it is not essential to getting the lathe going to start with. Do you understand how the belt drive is arranged? Your first picture in album shows it more assembled. It needs to be arranged so that the weight of the motor helps tension the belts. |
David George 1 | 13/01/2019 19:47:46 |
![]() 2110 forum posts 565 photos | Hi Ian the part that you are missing is the back gear. There is an eccentric shaft with handle and two gears which mesh with the two gears that are on the main shaft after the Bull gear has been disconnected. |
David George 1 | 13/01/2019 19:48:04 |
And the two covers for gears. David Edited By David George 1 on 13/01/2019 19:58:33 |
Ian Usmar | 13/01/2019 22:55:39 |
71 forum posts 10 photos | Bazyle, To be frank No. I understand the principle its how I set it up though? How will the motor assist with tension of the clutch is in between the motor and the lathe.
Bazyle | 14/01/2019 00:22:17 |
![]() 6956 forum posts 229 photos | Ian, look at the first photo in the 'Zyto owners only' thread. If you can set it up a bit like that, but with the mounting point nearer the late and the main arm leaning backwards then it puts tension on the belt. In the Zyto version he has an arm to hold it upright and apply tension. In David's second picture above there is a horizontal knurled nut which is another method of pushing the intermediate shaft assembly back which you might need if the motor weight is not enough. |
Ian S C | 14/01/2019 11:07:26 |
![]() 7468 forum posts 230 photos | The amount of belt tension can be adjusted on a hinged mounting plate by moving the motor further or closer to the hinge point. I might be worth turning your timing belt inside out, if nothing else it will be quieter. Ian S C |
