Manually letting off steam
Brian H | 05/01/2019 15:36:34 |
![]() 2312 forum posts 112 photos | I have bought a pair of safety valves to the Gordon Smith design and was surprised that there is no facility to operate them manually to check operation with the boiler in steam. Is this OK under the regs(used to be the Green Book) and has anyone modified their valves to allow operation manually? Brian |
Robert Atkinson 2 | 05/01/2019 18:45:39 |
![]() 1891 forum posts 37 photos | The boiler test code 2018 volume 2 section 13.1.5 says "It is considered good practice that every time steam is raised in a so sounds like it's not mandatory but I think you would need a good reason not to use a testable valve. Maybe boiler inspector can comment. |
Jon Lawes | 05/01/2019 19:08:48 |
![]() 1078 forum posts | I bet I'd scald myself. |
Paul Kemp | 05/01/2019 20:19:41 |
798 forum posts 27 photos | 'Testing' them at anything other than operating pressure proves nothing other than there is a free passage of steam so I don't see any real value in the practice. Few full size safety valves have that facility. For myself I am far more interested in that the valve lifts at the set pressure in normal operation. When lighting up a boiler the first thing I want to know is its operating pressure indicated by the red line on the gauge, no line no lighty, do not pass this point. Then I want to verify the water level and that the gauge glass passages are clear, with both these conditions satisfied plus an external visual inspection I proceed to raise steam, to the indicated operating pressure and confirm the safties lift - if not then either the pressure gauge is out of whack or the valves defective - further investigation required and until resolved the boiler is not fit for service. Lifting the valve manually at less than its operating pressure is far less important than a full pressure test and as Jon says not easy to do safely especially on a large or full size boiler, Paul. |
John Rudd | 05/01/2019 20:34:50 |
1479 forum posts 1 photos | Safety or relief valves are designed so no manual intervention is required.... I have worked on high pressure systems ( gas/steam/air/freon) where relief valve operation is a HSE demonstrable requirement.... |
Brian H | 06/01/2019 13:09:08 |
![]() 2312 forum posts 112 photos | I think that Robert Atkinson2 has the right idea and I would prefer to lift the valve just to make sure it hasn't stuck through no being used etc. Brian |
Paul Lousick | 08/01/2019 06:43:18 |
2276 forum posts 801 photos | As stated, it is good practice to ease the safety valve at every startup to ensure that is not stuck. Also good practice to raise the pressure to maximum while monitoring the pressure to see if the valves are set correctly and releases pressure. We do this all the time on full size steam engines. |
