Serious machine or toy?
Kiwi Bloke | 26/12/2018 09:43:26 |
912 forum posts 3 photos | I've been wondering about a small lathe. The Emco Compact 5 looks attractive, and is about the right size, but is it a dressed-up toy or an accurate machine, capable of sensible work (in steel)? A certain G Meek uses one: should that be recommendation enough? Any available will be fairly old by now - how do they wear? Also, is the milling unit worth considering? The restricted speed range, alloy headstock, saddle and tailstock, and the rudimentary fine feed for the milling unit's quill don't inspire confidence. What do users think? |
JasonB | 26/12/2018 10:11:14 |
![]() 25215 forum posts 3105 photos 1 articles | Not had a 5 but did have a Unimat3 to start with, made a Stuart 10V (steel and cast iron) on it as well as lots of other things. As long as you don't expect it to remove metal at the same rate as a M300 or master they are capable machines in the right hands. The worm and wheel arrangement for fine feed is no different to what you get inside the head of most of teh imported machines and good work is done with them too. |
Graham Meek | 26/12/2018 10:29:27 |
714 forum posts 414 photos | I would not be without my Compact 5. I am just in the process of doing a few upgrades on this machine. The gear train for screw cutting and fine feeds is a big plus. As is the induction motor and bet drive. I was fortunate in obtaining an "old stock" Austrian machine that had never been out of the box. I doubt you will experience any signs of wear provided the machine is used with some degree of care and respect. The milling head is a worthwhile addition, (still looking for one), but it is much better to have a stand alone machine if possible. Regards Gray, |
Chris Trice | 26/12/2018 12:11:02 |
![]() 1376 forum posts 10 photos | I'll second what Graham says. I have a Compact 5 as I needed a portable machine I could take from job to job. It's also whisper quiet in operation which is handy if you work indoors or have neighbours nearby. I've just bought a Compact 8 so might dispose of the 5 soon. |
Emgee | 26/12/2018 12:30:11 |
2610 forum posts 312 photos | Hi Kiwi use the Emco 5 cnc which is the same mechanically as the manual 5 except for ball screws in place of the normal threaded leadscrews. Emgee |
Graham Meek | 26/12/2018 12:45:36 |
714 forum posts 414 photos | With regard to the alignment of the milling head on the U3 and the C5. Neil Hemingway was selling during the 1980's an Alignment Attachment made for these machines. I designed and manufactured the attachments which needed no modification to the machine at all. Unfortunately I don't have a photograph of the attachment, but I think it does appear in one of the Model Mechanics available on this site. I do have the sketches I used at the time. Provided there was sufficient interest I could make them into drawings and maybe provide an article. Regards Gray, |
Chris Trice | 26/12/2018 19:17:41 |
![]() 1376 forum posts 10 photos | While you're here Graham, I noticed (in one of your books) you have (had) the Emco Maximat tool post grinder that appears to have the same motor as the Compact 5? Is this the case or is it one of the smaller ones as used on the vertical milling attachment, thanks? |
Martin Hamilton 1 | 26/12/2018 19:29:35 |
188 forum posts | Posted by Chris Trice on 26/12/2018 12:11:02:
I'll second what Graham says. I have a Compact 5 as I needed a portable machine I could take from job to job. It's also whisper quiet in operation which is handy if you work indoors or have neighbours nearby. I've just bought a Compact 8 so might dispose of the 5 soon. Chris just a few questions on your Compact 5 lathe, what sort of condition is it in & does it have extras with it. How much would you be asking for it if you decide to sell it & what part of the country are you. Thanks Martin. |
Neil Lickfold | 26/12/2018 20:49:34 |
1025 forum posts 204 photos | The compact 5 is a home hobby mill. Not an industrial power house. But many fine parts have been made on one for sure. It's more set up time to mill stuff etc, but great fun, and very easy to set up from turning to milling. Like a lot of thing the accuracy comes from preperation and thinking about how you do the job. Depending on the accessories you get etc, but on a friends one, he can turn a part, transfer the chuck to the rotary table and then do the milling work, then back onto the spindle and part off the workpiece with everything done at the same setup. So some advantages there for a small number of parts. Like any machine if looked after will last many many years. Neil |
Former Member | 26/12/2018 21:22:39 |
[This posting has been removed] | |
Bazyle | 26/12/2018 21:51:16 |
![]() 6956 forum posts 229 photos | It appears to have a fixed leadscrew nut. Not a big fan of that. I think you would be better off filling the empty machine space with another mill. |
Former Member | 26/12/2018 22:04:26 |
Danny M2Z | 27/12/2018 02:32:55 |
![]() 963 forum posts 2 photos | Many years ago I used to compete against an expert with my Free Flight models. John L, always had the custom turned venturies, needle assemblies and shut-off's for his power models and the most exquisite ball raced folding propellor hubs and Montreal stops on his competition rubber powered models. They were like the one's that I read about in overseas magazines. One day I was invited to visit my friend's house and he showed me his secret weapon, an Emco Compact 5 lathe. Of course John was too modest to admit that he knew how to get the best out of it but it was it was inspiring to see what was possible and a bit depressing to realise how much I needed to learn. Still learning btw but it's a nice little lathe (Emco C5), you could do much worse. * Danny M * |
Douglas Johnston | 27/12/2018 09:26:20 |
![]() 814 forum posts 36 photos | I started off with a compact 5 and used it for many years. It is a lovely machine and very well built but I did not like the fixed leadscrew. I built a Quorn grinder with it so it can handle reasonable sized jobs. |
Graham Meek | 27/12/2018 12:07:16 |
714 forum posts 414 photos | Posted by Chris Trice on 26/12/2018 19:17:41:
While you're here Graham, I noticed (in one of your books) you have (had) the Emco Maximat tool post grinder that appears to have the same motor as the Compact 5? Is this the case or is it one of the smaller ones as used on the vertical milling attachment, thanks? Hello Chris, My apologies for not responding earlier, I have only just read your post. It is true I do have an Emco SOD toolpost grinder for the Maximat Super 11. The motor on this attachment is much smaller than the C5 main motor. However the C5 Milling attachment motor is I would say one in the same. Cross checking the Emco part numbers there are a great many similarities between the last 4 digits and the voltages/frequencies. I would in general expect the main part numbers to be different, as usually these first digits apply to the machine type. Also they would need to be supplied in green or yellow colours depending on application. I had just better add the Maximat V10 uses a derivative of the Compact 8 toolpost grinder which has an AC motor with brushes and not an induction motor as on the Emco SOD. The method of holding the grinding wheels is also different on the V10/C8. This is based on the 8 mm draw-in collet. I am convinced, but not sure, the spindle used in the V10 grinder was the original spindle, supplied as an accessory, for using collets on the Unimat SL. Regards Gray,
Chris Trice | 28/12/2018 01:54:35 |
![]() 1376 forum posts 10 photos | Thanks for the info Gray. It's appreciated. I'm a big fan of your stuff and writings, and I've got one of your screw cutting clutches on my Super 7 courtesy of yourself and Kwil. In fact it was your workshop projects book where I saw the tool post grinder that piqued my interest. Is there a plate on the motor stating the motor power? Pro Machine Tools offer a motor that I could make use of if the specs are similar. Thanks again. |
Graham Meek | 28/12/2018 17:03:27 |
714 forum posts 414 photos | Hi Chris, I will have to take your word for it as regards the S7 screw cutting clutch. My memory is shot these days. The motor plate reads, 1 phase, 240 v, 0.185 kW, 1.5 A, 2600/Min and 6 Micro F 400v DB. Regards Gray, |
Bazyle | 28/12/2018 17:59:03 |
![]() 6956 forum posts 229 photos | My dislike of the fixed leadscrew is based on my Hobbymat which is 1mm pitch so takes an age to move the saddle out of the way. Mostly therefore I only use the topslide unless threading or needing a true const dia workpiece. If the pitch is courser it might be less of a pain. Every now and then I look at the Hobbymat and wonder if it is worth making a regular leadscrew for it but it's tiny bed means the comparatively hefty leadscrew is actually part of the structure. |
Graham Meek | 28/12/2018 18:21:15 |
714 forum posts 414 photos | As one of the upgrades planned for my Compact 5 I have always intended to make a new carriage with a pair of clasp nuts for the leadscrew. The rapid traverse would be similar to the Myford ML 10 which uses the leadscrew as a rack. In my version this rapid traverse is geared down to make moving the carriage easier, and more sedate. A dial on the pinion engaging the 1.5 mm pitch leadscrew acting as an indicator to aid closing the clasp nuts during screwcutting. Regards Gray, |
mike T | 28/12/2018 18:27:45 |
221 forum posts 1 photos | The carriage of the Compact 5 does not have adjustable gibs like a conventional lathe, instead it has a pair of plastic keep plates which clamp ((loosely) the carriage to bed ways. There seems to be no provision for adjusting the play between the keep plates and the bed ways. As a result the carriage can rock slightly spoiling the accuracy and surface finish. What do you guys do to reduce the free play between the carriage and the bed ways? Have any of our Compact 5 experts found a better way of providing adjustment for the carriage to the bed ways? Mike Edited By mike T on 28/12/2018 18:45:52 |
