Laser centre finder
Stephen Follows05/12/2018 14:31:54
119 forum posts
I have been looking at a laser centre finder that fits permanently to a pillar drill. I would like to fit one to my Warco mill but the drill one will not fit. Cannot find on that does. Has anyone fitted such a device to a mill?
Michael Gilligan05/12/2018 15:40:36
23121 forum posts
1360 photos
Stephen,
May I suggest that you read this thread: **LINK**
https://www.model-engineer.co.uk/forums/postings.asp?th=92281
There was some very useful discussion.
Personally; I don't think that a "pillar drill" style of device would be sufficiently accurate for use on the mill ... but your requirements may differ.
geoff adams05/12/2018 16:19:54
214 forum posts
207 photos
Stephen
i have a laser center finder it has a 6 mm shank and will fit any drill chuck i use on my mill drill and cnc mills got from ebay i think it was £50.00 well worth the money
i got a tormach cnc mill about 3 months ago and it has probing on it been playing with it over the weekend can find center of a bore corner of a vice or probe two edges to set a datum at the touch of a button wish i had this back in the 80s when i was setting and programming cnc mills on more edge finders and clocks
Geoff
Stephen Follows05/12/2018 21:37:53
119 forum posts
Thanks for replies. Looks like the collet mounted type is the answer for decent accuracy.
Jon06/12/2018 19:41:57
1001 forum posts
49 photos
Its only as accurate as the lasers zeroed, plus theres way too much spread to pinpoint.
Theyre that good i imported a quality one from California when first came out 2002, initial trial twice and never used since. You will get a far more accuracy with mark 1 eye ball.
Phil Whitley06/12/2018 19:47:53
1533 forum posts
147 photos
https://www.youtube.com/watch?v=u1BH00OL6Q0
try this one, on the very excellent Dan Gelbarts you tube channel.
Phil
Edited By Phil Whitley on 06/12/2018 19:48:21
Michael Gilligan06/12/2018 22:42:39
23121 forum posts
1360 photos
Posted by Phil Whitley on 06/12/2018 19:47:53:
That would be the commercial version of the one that started our discussion in 2014
... as per my post, above.
bricky07/12/2018 00:34:13
627 forum posts
72 photos
I have one and use it on the mill for setting vice jaws true.When drilling to a centre pop I use a sticky pin as I am never quite sure that the beam is centre of the pop.I find the sticky pin near enough as any drill can wander slightly and I am not a toolroom fitter and never will achieve those tolerances and I dout many do.
Frank
