A fine parting tool
Kevin D21/11/2018 12:45:03
16 forum posts
86 photos
A HSS broken cutting saw blade was begging for a second life. Taper groung faces 80dia. x 1.6 thick HSS Co5% used for cutting s/s tube. When ground it gives about 10mm cutting depth. The first design has the blade center 1mm below lathe center height. It allows the blade to be rotated up to tool center and gives some top rake.The next design will only have 0.5mm below. This would avoid excessive grinding to obtain front clearance. If it digs in it rotates down and away from work. Great for circlip and oring grooves.p9030199.jpg p9030201.jpgp9030202.jpgp9030200.jpg
larry phelan 121/11/2018 15:57:27
1346 forum posts
15 photos
Neat ! I like it ! The things some guys come up with ??????
Stuart Bridger21/11/2018 16:21:12
566 forum posts
31 photos
Plenty of scope for resharpening there
Ady121/11/2018 19:37:34
6137 forum posts
893 photos
Nice one, a really useful bit of recycling there
It's an old idea but a good idea, If memory serves Herbert or Ward used the same system on capstans
Edited By Ady1 on 21/11/2018 19:44:47
Mick B121/11/2018 19:50:37
2444 forum posts
139 photos
I came across circular form tools in the 70s on CVA cam autos. Good way to use up a small slitting saw.
Edited By Mick B1 on 21/11/2018 19:51:22
