Yes - I should have labelled it....
Iain Downs | 18/11/2018 18:39:50 |
976 forum posts 805 photos | Hi, all. Over the last couple of years I've bought a bunch of material for one project or another. Most are still on the drawing board and I've lost track of quite a few of them. One thing that's left me with is some metal whose purpose I no longer recall - if, indeed, I bought it for something in particular and not just because it might come in useful someday. There's a block I will use for some bearings if it's cast iron - and not if it isn't. How do I tell? I thought I could scrape a bit - steel seems sticker to me than cast iron, but this wasn't conclusive. I can probably try and machine some. My experience is that cast iron comes of as grit and steel as streams or chips. Is this reasonable accurate? Is there any easy way of doing this? Thanks
Iain |
JasonB | 18/11/2018 18:41:39 |
![]() 25215 forum posts 3105 photos 1 articles | Put it against your bench grinder, if grey CI then you will get dull red sparks |
mechman48 | 18/11/2018 19:15:07 |
![]() 2947 forum posts 468 photos | File it; if CI it will produce grey dust. |
not done it yet | 18/11/2018 19:43:57 |
7517 forum posts 20 photos | Turning or milling will easily discern between the two - like the filing suggestion, by mechman48 |
Martin Connelly | 19/11/2018 08:04:00 |
![]() 2549 forum posts 235 photos | I can usually tell when I am working with cast iron because it smells what I can only describe as earthy. Most other materials don't have such a distinctive smell. Martin C |
Jon Lawes | 19/11/2018 20:52:36 |
![]() 1078 forum posts | Posted by Martin Connelly on 19/11/2018 08:04:00:
I can usually tell when I am working with cast iron because it smells what I can only describe as earthy. Most other materials don't have such a distinctive smell. Martin C I'm glad I've heard someone else say it! I'd never have admitted it myself otherwise. It does have a distinctive smell. |
Fowlers Fury | 19/11/2018 21:16:58 |
![]() 446 forum posts 88 photos | Easy - if you're married...... Machine, file, emery or whatever the metal then wash your (black) hands in the domestic sink. |
colin vercoe | 19/11/2018 21:31:48 |
72 forum posts |
Grinder dull red sparks -cast iron bright yellow - steel
