Lost key for Simat 101 crank chuck
I need help to find the item
Andrea Giovannini10/11/2018 18:00:56
2 forum posts
Dear friends
I need your help because I have lost the key of the chuck on my old lathe Simat 101. It is a crank chuck with 72 mm diameter. I am not able to post a picture of it because I am not expert. So I'd like to know if there is a seller willing to sell this key or someone that has one and give me for money.
I canot use the lathe without this item.
Please give your suggestions or your help. Thank you
Andrea Giovannini
Alessandria Italy
Emgee10/11/2018 19:24:02
2610 forum posts
312 photos
Is it a drill chuck type key ?
If so what diameter are the holes in the chuck where the key fits for opening/closing ?
Emgee
David George 110/11/2018 20:55:23
2110 forum posts
565 photos
Hi Andrea I have a K1 chuck key that has a 4mm nose is that what you need.
David
Michael Gilligan10/11/2018 21:59:38
23121 forum posts
1360 photos
Posted by Emgee on 10/11/2018 19:24:02:
On the other thread **LINK**
https://www.model-engineer.co.uk/forums/postings.asp?th=138783
Peak4 provided an useful photo of the key design.
... I've not seen one like it before dont know It's similar to drill chuck key but not a bevel gear !!
Michael Gilligan10/11/2018 22:33:43
23121 forum posts
1360 photos
idea
See the top-left item on the 'Accessories' here: **LINK**
http://www.rejon.co.uk/manix_ml210.php
Edit: Couple of photos of the chuck, on the Record version of the ML210, here:
https://www.thewatchforum.co.uk/index.php?/topic/63667-finally-some-lathe-work/
Edited By Michael Gilligan on 10/11/2018 22:47:26
peak411/11/2018 00:30:43
2207 forum posts
210 photos
Posted by Michael Gilligan on 10/11/2018 22:33:43:
idea
Also on the other thread, Rejon replied to me and said they couldn't supply one; at least that's what I took their reply to mean. indecision
Bill
Martin Connelly11/11/2018 06:53:11
2549 forum posts
235 photos
Short term fix might be a strap wrench and tommy bar. I have a small chuck with the outside ring knurled and a tommy bar hole and that is all that it needs for a good grip.
Martin C
Michael Gilligan11/11/2018 07:38:33
23121 forum posts
1360 photos
Posted by peak4 on 11/11/2018 00:30:43:
[ ... ] Also on the other thread, Rejon replied to me and said they couldn't supply one; at least that's what I took their reply to mean. indecision
My apologies, Bill ... I missed that important point. blush
Michael Gilligan11/11/2018 11:10:31
23121 forum posts
1360 photos
At least I have learned something from this discussion:
The geometry troubled me a little, as I have only really considered quite narrow 'contrate' wheels ... a little searching revealed that this might be better be termed a 'Crown Face Gear' and that the geometry can indeed be a little complex: **LINK**
http://spiralbevel.com/crown_face
[ not that I would really expect the gearing of chuck and key to be made to close tolerance ]
Grizzly bear13/11/2018 18:12:31
337 forum posts
8 photos
Hi Andrea,
Update please.
Have you found your chuck key?
Bear..
