Maurice | 22/09/2018 17:10:27 |
469 forum posts 50 photos | I have just seen a close up picture of an engine room telegraph on the net. Two or the commands are "Pump Over" and "Stop Pumping Over". Can anyone explain what they mean please? Maurice |
Brian Wood | 22/09/2018 18:49:14 |
2742 forum posts 39 photos | As a landlubber I would expect those to be commands for bilge pumping, in essence ON and OFF Others may know better of course Brian |
Martin W | 22/09/2018 19:28:45 |
940 forum posts 30 photos | Another landlubber contribution. Could it be pumping fuel from on thank to another to trim the ship or perhaps pumping liquid ballast again to trim the ship. All guesses!!!! I look forward to the correct answer being posted here. Martin
Bazyle | 22/09/2018 19:39:41 |
![]() 6956 forum posts 229 photos | I think it is for the pump room of a bulk carrier or RFA tanker to either control liquid ballast pumping to compensate for cargo changes or shifting the cargo itself. Bilge pumping would more likely be controlled by the engineroom without instruction from the bridge when they noticed their feet getting wet. Martin typed faster. If the image you found is the one from the Charles Beeghly then the puzzle is more why a lakes steamer would need to make smoke long after radar was invented. Edited By Bazyle on 22/09/2018 19:44:11 |
SillyOldDuffer | 22/09/2018 19:48:00 |
10668 forum posts 2415 photos | I knew a Naval Officer who said he needed to 'Pump Ship' every time he headed for the bogs. I think he meant he had to see a man about a dog. I guess pumping ship is a common operation, especially if she has a leaky bottom... |
Brian Sweeting | 22/09/2018 19:49:26 |
453 forum posts 1 photos | According the HMS Belfast, it was used to signal pumping fuel to another vessel. |
Neil Wyatt | 22/09/2018 21:43:49 |
![]() 19226 forum posts 749 photos 86 articles | My researches also showed it was on Belfast's telegraph.
Maurice | 22/09/2018 22:43:57 |
469 forum posts 50 photos | Thanks for the replies gents. Pumping fuel makes sense. thanks again. Maurice |
Gray62 | 22/09/2018 22:53:07 |
1058 forum posts 16 photos | Pump over was the EOT command to commence pumping from an auxiliary tanker or larger ship and was known as RAS, 'Refuelling At Sea'. |
