3 phase converter help needed please
George Jervis | 22/09/2018 11:28:41 |
113 forum posts 76 photos | Hi everyone, I'm looking for some help we a 3 phase converter I've been given a while ago, and never used a 3 phase converter before I'm puzzled on how to set it up to run? I have a small horizontal mill which was on single phase and decided to buy a new 1\2hp 3 phrase motor to go with converter (the motor company helped to make sure I had the correct motor for the converter) so I can better control the cutting speed, instead of having to mess around with the rats nest of pulleys every time I wish to change speeds. My issue is i have no information/instructions on how to get the inverter to work or how to set the parameters? A electrician friend helped me with the wiring installation so that been done correctly. Would any kind more knowledge person be able to help please, I'm fairly new to the forum but I've managed to put some pictures in a album Many thanks in advance George Edited By George Jervis on 22/09/2018 11:50:39 |
Speedy Builder5 | 22/09/2018 11:38:27 |
2878 forum posts 248 photos | What sort of phrases did you want to convert - (Tongue in cheek) |
Martin Cargill | 22/09/2018 11:50:48 |
203 forum posts |
A quick google found the manual I didn't download it but it will probably have a "quick start" guide. The manufacturer will have a technical helpline that should give you assistance with parameter issues. Martin.
not done it yet | 22/09/2018 12:57:40 |
7517 forum posts 20 photos | George, The first thing to do is check that the motor is wired for delta and not star. The VFD factory default settings should be good, as a starting point, to get running. Remote starting and stopping is usually a more advanced set up, as are individual trip settings for your particular circumstances. |
George Jervis | 22/09/2018 13:08:30 |
113 forum posts 76 photos | Hi The motor company told me to change the jumpers to DELTA configuration as they were sold in star originally, so I've changed them to DELTA before wiring everything up George |
David Jupp | 22/09/2018 14:41:39 |
978 forum posts 26 photos | Manual is available from Schneider Not the most user friendly of manuals, but being a fairly old design there aren't many options to worry about. Unusually this device doesn't have run/stop buttons on the front, so switches of some kind will have to be wired. |
George Jervis | 23/09/2018 13:05:39 |
113 forum posts 76 photos | Hi I've managed to print out a copy of the Manuel and followed it best I can but still no joy it seems like the parameters are locked and can't be changed? So inputting the motor plate info can't be done? I checked the wiring again today that's okay. The motor is brand new from "the motor company" aka (TEC) which are about a miles ish from my home so no postage to worry about damage. Has anyone got any ideas please George |
Gary Wooding | 23/09/2018 13:47:06 |
1074 forum posts 290 photos | Are the parameters locked even though the L2A parameter shown on page 56 is set to Yes? |
not done it yet | 23/09/2018 13:49:59 |
7517 forum posts 20 photos | Two of my inverters, I think, have one particular program setting number which locks, or unlocks, the programming - to avoid individuals, on the shop floor, tampering with the settings. I think that setting could only be accessed, on one VFD, after the it was left unpowered for some time. I can’t remember the Schneider manual as I didn’t really need it - that VFD had failed, probably due to old age. |
David Jupp | 23/09/2018 13:50:21 |
p. 53 onwards of the manual covers parameters modification and gives some examples. ItH should be set to nominal motor current (for thermal protection), take from motor plate. bFr set to motor base frequency; 50 or 60 (almost certainly 50) The setting method is very clunky, so read the examples carefully. ItH & bFr are both level 1 parameters. You can define some preset speeds to call depending on switch positions. LSP, HSP, JOG, S3 S4. All these are 'Level 1' parameters, so follow examples / flowchart for level 1. Since you have a 0.37kW motor and a 0.37kW drive the factory default settings for motor should be reasonable - if in doubt you could perform a FCS (a level 2 parameter). |
Martin Cargill | 23/09/2018 15:59:11 |
203 forum posts | From your photos it looks like the drive is ready to go ( the RDY on the display). To give further assistance: Can you photograph the wiring that you have going into the drive. A photograph of a sketch of the wiring would also help. Also a list of the parameters and what you have them set to would also help Martin
George Jervis | 23/09/2018 16:48:21 |
113 forum posts 76 photos | Hi everyone, Thank you for the continued help I've managed to check and it's set up to 50Hz and L2A is on YES as well, but still no joy? One of the parameters say I have 235 to 236 volts going into the converter so I have enough voltage going in. Knowing my luck, it'll be something really simple lol (I hope) George |
John Rudd | 23/09/2018 17:03:10 |
1479 forum posts 1 photos | As Martin has said above, we need a diagram of how the inverter is wired, especially the stop/start and speed inputs. Reading the manual, it looks like these inputs are missing hence the 'no go' Page 47... The front panel controls seem lacking in functionality... |
George Jervis | 23/09/2018 17:43:19 |
113 forum posts 76 photos | Hi Martin, I've put some more pictures in a album of the wiring to the motor and converter The wiring I've used is 1.5mm2 sc 4 core
Converter wiring as follows U is wire 3 V = 2 W=1 E tm earth And the motor is wired too U1 is wire 3 V1 is 2 W1 is wire 1 Earth is E I'll try and write what the parameters I have on the converter at the moment but this might not be on here until later or tomorrow morning. Many thanks again for the help George |
David Jupp | 23/09/2018 17:59:50 |
978 forum posts 26 photos | What about the control wiring ? Nothing will work without that. |
John Rudd | 23/09/2018 18:28:46 |
1479 forum posts 1 photos | Posted by David Jupp on 23/09/2018 17:59:50:
What about the control wiring ? Nothing will work without that. Err...like what I said above....George you need some more string....and leave the inverter settings alone for the time being...concentrate on getting the motor to turn first.. |
George Jervis | 23/09/2018 18:39:32 |
113 forum posts 76 photos | This is were I could have gone wrong ? Does this mean I have to have a separate on off switch? I had a few years ago a 3 phase converter on a large drill press that I just pressed the enter button for on or off and used the arrows up and down to increase or decrease the speed but I have sold that now. I had assumed that this 3 phase converter would be the same?? George |
John Rudd | 23/09/2018 18:48:21 |
1479 forum posts 1 photos | George, Can you fit a short length of single core wire to connect LI1 and +24v together, then another wire to +10 and AI1 terminals? Then tull us what happens...Hopefully the motor runs at full speed.. |
George Jervis | 23/09/2018 18:57:11 |
113 forum posts 76 photos | I'll have to try that tomorrow morning and I'll let you know what happens, fingers crossed Thank again everyone for trying to figure this out George |
Martin Cargill | 23/09/2018 20:29:13 |
203 forum posts | George. Don't do anything yet with regard to trying to start the motor. We need to know a bit more about how you have the motor wired. What you have shown so far is the power wiring, As John Rudd has pointed out the control side of the wiring is missing. What I'm not sure of just now is how you have connected the motor. Does the wiring run directly from the converter to the motor, or does it go through the original switchgear? Does the power supply to the converter go through the original switchgear or direct from the mains? Martin |
