Neil Wyatt | 11/09/2018 19:42:01 |
![]() 19226 forum posts 749 photos 86 articles | I'm guess that, like me, you've probably bought sets of bits that include a weird one that resembles a drill on the end but is studded with coarse rectangular teeth. My understanding was always that they are for drilling a hole then working sideways like a crude saw. I finally used one today and it worked very well. The material was the 305mm very heavy density plastic pipe that is the tube for my dobsonian telescope. I had to enlarge the focuser hole to about 100mm, bigger than my largest holesaw and anyway no centre to guide one. It was actually fairly easy to cut a neat hole and just tidy it up with a rasp. The focuser has a cover plate so a perfect hole was not needed although it came out much tidier than I expected. Even on plastic it cut rather than melted (it was a TiN coated one) and I found gently working it up and down sped things up, presumably by keeping the teeth clear. Nice to know they work, wonder if I will ever use one again? Neil |
AJW | 11/09/2018 20:37:02 |
![]() 388 forum posts 137 photos | I have a set of them. Just need the telescope to use them! Alan |
Mike Poole | 11/09/2018 21:15:35 |
![]() 3676 forum posts 82 photos | I have a few kicking around, will have to give them a go. mike |
Neil Wyatt | 11/09/2018 21:33:09 |
![]() 19226 forum posts 749 photos 86 articles | I should say I used it in a hand drill - I coldn't fit a 1' by 5'8" tube on my mill... |
Dalboy | 11/09/2018 21:42:29 |
![]() 1009 forum posts 305 photos | If they are what I think then I use them a lot when doing piercing work on my woodturning great tools and remove material very fast |
Brian G | 12/09/2018 07:45:54 |
912 forum posts 40 photos | Posted by Neil Wyatt on 11/09/2018 21:33:09:
I should say I used it in a hand drill - I coldn't fit a 1' by 5'8" tube on my mill... How fast were you winding the handle to worry about it melting the plastic? Brian |
David Standing 1 | 12/09/2018 12:34:07 |
1297 forum posts 50 photos | Posted by Neil Wyatt on 11/09/2018 21:33:09:
That's because you have a Fisher Price toy mill |
Ian S C | 12/09/2018 15:02:14 |
![]() 7468 forum posts 230 photos | I think Neil used a hand held power drill, hand power doesn't work too well sideways. Ian S C |
