Where to get a part made?
Tony Fisher28/08/2018 19:12:33
3 forum posts
Please can someone tell me where I can get this made - A 45x45x45mm solid cube of steel with 20mm deep M6 threaded holes in the middle of each face. So that's 6 holes in total. The holes can be a bit deeper and even go all the way through. I can even supply a bar of steel 45x45x100mm if absolutely necessary.
I thought this would be really simple to get made but 2 companies in my home seemed completely uninterested and treated my request as annoyance. I then contacted some online companies but most just ignore me or replied once but didn't really seem interested either. It's not as if I am expecting to get it done cheaply. I just want to pay the going rate and get it done. This has now been dragging on for months.
Neil Wyatt29/08/2018 08:55:30
19226 forum posts
749 photos
86 articles
Hello Tony,
That's a pretty simple part, depending on how accurately it needs to be made and how well you need it finished.
If it's just a case of sawing to length, facing off the sawn surface, drilling and tapping the holes its shouldn't more than an hour even with a good level of care in setting up.
If you give your location, I'm sure someone close to you will be able to assist.
Ian Parkin29/08/2018 11:18:55
1174 forum posts
303 photos
I'm in sheffield
if you send me the steel i'll do it for £15 plus return postage
milled to square tapped and ground surface finish
Ian
Ian S C29/08/2018 11:38:56
7468 forum posts
230 photos
That's an apprentice filing exercise, hacksaw, file, then marking out and drilling.
Ian S C
Martin W29/08/2018 11:40:13
940 forum posts
30 photos
Tony
If you supply the bar and it is 45mm square to start with then the finished item will actually turn out, pun not intended, to be less than 45mm square.
I know that I am stating the obvious but it was just a thought.
Martin
Tony Fisher29/08/2018 12:23:16
3 forum posts
Posted by Ian Parkin on 29/08/2018 11:18:55:
I'm in sheffield
Ian
Thanks. The finish is unimportant since it will not be seen or touching anything. The supplier of the bar has now told me he can provide 45mm lengths so I'll order some and contact you when it arrives.
I have had such a negative response to this request elsewhere I hope I have explained it correctly. People seemed to think tapping to that depth is not easy. Maybe I have been approaching the wrong companies.
Thanks also to the other people who have replied.
Ian Parkin29/08/2018 12:45:58
1174 forum posts
303 photos
Actually i do have some 45 in stock so let me know by pm if you want it doing?
larry phelan 129/08/2018 18:48:48
1346 forum posts
15 photos
Tony,
Your experience does not surprise me. Many moons ago I needed to get some simple drill bushes made,and I got exactly the same response [I posted a post about this some time ago ]. I was told,in as many words to just "Piss off".
Your best bet is to find some small guy locally,who would be able,and willing to oblige. Believe me,there is one out there somewhere.
This is not a difficult job,so any small shop would be well able to do it
Hell,even I could do it !!devil
Tony Fisher01/09/2018 12:19:36
3 forum posts
I'd like to give a massive public thanks to Ian for making the part. The reaction to my post has been amazing and I think you have a very special forum here.
