Alan Girvan | 21/08/2018 19:14:34 |
40 forum posts 3 photos | I have a rotary table with no name on it but it looks identical to Warco HV6 6inches. i also have 3 dividing plates for it to make it into an indexer the trouble is the clip that holds the sector arms is missing. An ordinary C clip keeps coming off, would anyone know where these clips can be purchased. Thanks in anticipation for any help you can provide. Alan. |
JasonB | 21/08/2018 19:19:24 |
![]() 25215 forum posts 3105 photos 1 articles | Should be easy enough to file one up from a bit of brass as that is all they are. |
Alan Girvan | 21/08/2018 19:29:12 |
40 forum posts 3 photos | This clip is made out of spring steel with a springy curve in it to hold it tight against the brass washer |
JasonB | 21/08/2018 19:45:39 |
![]() 25215 forum posts 3105 photos 1 articles | So it is now I've had a look, same applies a bit of annealed spring steel and a file then clamp between some rods to put the wavy bends in it. You could even do it with thin steel sheet a sit does not need a lot of spring. Or make a flat clip and add a belleville washer or similar to get the spring. |
not done it yet | 21/08/2018 20:47:53 |
7517 forum posts 20 photos | Ask Warco? |
Paul Lousick | 21/08/2018 23:07:32 |
2276 forum posts 801 photos | Instead of searching for a "C" clip try "E" clip. Lots shown on ebay or from industrial fastener suppliers. Paul. |
JasonB | 22/08/2018 06:57:04 |
![]() 25215 forum posts 3105 photos 1 articles | E clip won't work, it needs to provide some spring tension when compressed. It's the "C" shaped part to the right of the quadrant in this pic |
larry phelan 1 | 22/08/2018 10:07:44 |
1346 forum posts 15 photos | I had a similar problem with my table where I found that the spring clip did not always hold the arms in place,so I replaced it with a circlip. That solved the problem,but as has been said they are easy enough to make from a small piece of brass. I made a special sector arm when I found that I could not obtain one particular division using the existing arms [one of several mistakes I found in the tables ],so they are quite easy to make. |
Howard Lewis | 25/08/2018 12:38:41 |
7227 forum posts 21 photos | If you have a chart with the 6 inch Rotary table, do be wary, and check. The Vertex HV6 chart had eight errors or omissions, at one time. (Has it still?) One of the errors cost me a week in three scrap workpieces, and then working out what was wrong, before finally making what I had set out to do. Howard |
