CL500M Clarkes Lathe soft jaws
CL500M Clarkes Lathe soft jaws needed.
Simon Tyler07/08/2018 15:00:33
4 forum posts
Hi all
Does anyone know where I can get (or the size I need), soft jaws for the 5" chuck on the clarkes Lathe (CL500M). I asked Clarkes and they don't know (figures).
surely it's standard.
Thank you.
Simon
JasonB07/08/2018 18:39:53
You could try Rotagrip, they do softjaws for some of the imported chucks and that is where I got mine. They start at the bottom of the 2nd page and carry on on the next
Simon Tyler07/08/2018 20:09:01
4 forum posts
Posted by JasonB on 07/08/2018 18:39:53:
Do you have the clarkes lathe?
JasonB07/08/2018 21:25:52
No, You will need to measure your existing jaws and see if there is a matching size, or give them a ring and they may know what fits.
Danni Burns15/05/2021 14:29:53
69 forum posts
42 photos
Hi all
Did anyone sort soft jaws for CL500M? Could you advise of spec please?
Thanks
martin perman15/05/2021 15:22:31
2095 forum posts
75 photos
As far as I'm aware they dont exist.
Martin P
old mart15/05/2021 15:57:37
4655 forum posts
304 photos
Remove the jaws and carefully measure them, including the pitch of the teeth. Also measure the chuck diameter, is it 5" or 125mm? Post the dimensions and keep your fingers crossed.
Danni Burns15/05/2021 17:51:02
69 forum posts
42 photos
Hi Mart
I'd say the Chuck is 51/8" and pitch seems to be 6mm with (3mm gap & 3mm teeth)
Stamp reads: 7230 if that means anything.
20210515_175035.large.jpeg20210515_175104.large.jpeg20210515_173317.large.jpeg20210515_172920.large.jpeg
Hows my luck?
DiogenesII15/05/2021 19:23:29
859 forum posts
268 photos
It'd be helpful to know the width and slot dimensions.. ..If it's any help, the Warco 125mm ('Fuerda' brand) chuck soft jaws are 6.1 mm pitch, 56mm long, 16mm wide and 45mm high, with an 8mm high slot.. ..the bottom of the slot is about 6.8 above the ends of teeth / top of scroll..
old mart15/05/2021 19:48:54
4655 forum posts
304 photos
It's surprising how many people don't know what pitch means. Please measure from the FRONT of the first tooth to the FRONT of the last tooth, no.7. The chuck is likely 130mm. We need the width of the slot in the jaw and the width of the jaw. The number is a serial number and the chuck body should have it also, it has no other significance.
Danni Burns15/05/2021 19:58:40
69 forum posts
42 photos
These are:
54mm long (not important)
16mm wide (same)
42mm high (not important)
bottom of slot to ends of teeth: 7mm (compared to 6.8) - do you have some that you could double check?
Danni Burns15/05/2021 20:07:34
69 forum posts
42 photos
DiogenesII15/05/2021 21:04:21
859 forum posts
268 photos
It's looking good, I'll put some pics up as soon as I've sorted them out.. ..a few minutes (hopefully)
Edited By DiogenesII on 15/05/2021 21:04:48
DiogenesII15/05/2021 21:40:12
859 forum posts
268 photos
img_2.jpgimg_1.jpgimg_8.jpgimg_7.jpgI'd say your luck is pretty good.. ..the figures vary by some fraction of a mm here an' there, but mostly to do with holding calipers in one hand and camera in the other on the floor of a harshly-lit shed..
I'm too tired to work out the order & captions, so note that pitch is about 6.05, but they need to be a very free fit in the scroll, so that will be okay - they're also not the easiest things to measure, being curved.. 6.1 was from Warco's website, I got 36.32 over 6 teeth on the edges..
Edited By DiogenesII on 15/05/2021 21:49:45
DiogenesII15/05/2021 21:47:58
859 forum posts
268 photos
To keep things clearer, thought I'd add this bit last.. ..they're from Warco, listed on the invoice as Soft Jaw Set SJ-11-125; they aren't listed on the website as that, so it might be best to ring them, and in any case it'd be worth checking the price, probably £thirty-something.. They are made by 'Fuerda'. .img_9.jpg
Edited By DiogenesII on 15/05/2021 21:52:21
Danni Burns15/05/2021 21:57:54
69 forum posts
42 photos
Marvelous
Thanks very much
DiogenesII16/05/2021 09:19:05
859 forum posts
268 photos
Doing a bit more legwork this morning, Rotagrip's CC13 look like they'd also probably fit;
Rotagrip - Soft Jaws Chineses 125mm Chuck
Danni Burns16/05/2021 10:07:57
69 forum posts
42 photos
Thank you again for your efforts. Always nice to have options.
I wonder if any sellers at shows have these? They could shift a good few pairs if not greedy £££
old mart16/05/2021 20:31:59
4655 forum posts
304 photos
What happened to the op?
Danni Burns16/05/2021 22:17:56
69 forum posts
42 photos
What do you mean Mart? Op?
