Member postings for Simon Tyler
Here is a list of all the postings Simon Tyler has made in our forums. Click on a thread name to jump to the thread.
Thread: Clarke CL500M power feed
05/01/2019 13:27:29
I have put some pics of the the lathe here...
05/01/2019 13:23:39
Hi
I've searched and not found anyone that has not converted a Clarke CL500M to have powerfeed in X for milling.
*Before everyone dives in and tells me to get a different lathe, that does not help my issue. I have the lathe and it's done me well.
The lathe has power feed in X when using the lathe option, but not when using the milling option. Normally this is not an issue dong the jobs I do. But I've been slitting slots in shafts and have 800 to do and wanted to add power feed so I can debur whilst slitting. A powerfeed would save me about 3days of work so if I spend a day adding it then it's worth doing and having for future use.
I've seen various power feeds on ebay for approx £200, but they obviously don't have the same setup as the Clarke lathe and wondered if anyone has converted to suit.
https://www.ebay.co.uk/itm/X-Axis-Power-Feed-Kit-for-BRIDGEPORT-Milling-Machine-240-volt-model/371969858074?hash=item569b219a1a:g:EIUAAOSwBahVdck3:rk:1f:0
This sort of device can be bought quite cheap and I was wondering if I could make a simple conversion plate to mount it on and maybe turn up a bush to convert the 12mm diameter shaft the CL500 has to suit.
Anyone been there with this.
Si
Thread: CL500M Clarkes Lathe soft jaws
07/08/2018 20:09:01
Posted by JasonB on 07/08/2018 18:39:53:
You could try Rotagrip, they do softjaws for some of the imported chucks and that is where I got mine. They start at the bottom of the 2nd page and carry on on the next
Do you have the clarkes lathe?
07/08/2018 15:00:33
Hi all
Does anyone know where I can get (or the size I need), soft jaws for the 5" chuck on the clarkes Lathe (CL500M). I asked Clarkes and they don't know (figures).
surely it's standard.
Thank you.
Simon
