Mellor lathe
Mellor lathe spares and parts
Spencer Ord27/07/2018 13:53:54
14 forum posts
14 photos
Hi everyone. I have just finished refurbishing a Mellor lathe. I am desperately trying to find a Mellor lathe travelling steady. If anyone has one or no the location of one for sale could you let me know please. Many thanks
Brian Oldford27/07/2018 15:19:50
686 forum posts
18 photos
You might struggle to find an original accessory. However, depending upon centre height you might be able to roll your own from one of the excellent casting from http://www.collegeengineering.co.uk/product-category/castings/steady-castings/
Michael Gilligan27/07/2018 15:36:34
23121 forum posts
1360 photos
That should have been a very useful link, Brian yes
... But all variants of the steady castings appear to be 'unavailable'.
Any idea if this is a temporary glitch, or a sign of decline ?
John Haine27/07/2018 15:48:23
5563 forum posts
322 photos
CES (the new owners) have stopped supplying castings and can't be bothered to update their website
Michael Gilligan27/07/2018 15:50:47
23121 forum posts
1360 photos
Thanks, John ... It's as I feared.
Spencer Ord28/07/2018 08:44:10
14 forum posts
14 photos
Ok. Thankyou for the information. I had a good result finding the original fixed steady. I will keep serching.
Ian S C28/07/2018 10:44:20
7468 forum posts
230 photos
There is the possibility of fabricating one from steel, a welder would be handy but not essential.
Ian S C
duncan webster28/07/2018 11:45:18
5307 forum posts
83 photos
Hemingway do a kit for the Myford 7 series. My 5" centre height lathe has a Super7 steady mounted on a packer block, works OK as long as you dn't want huge diameter
Howard Lewis28/07/2018 15:26:05
7227 forum posts
21 photos
Like Duncan, my Peter "Bushy" Robinson Slotting Tool for a Series 7 Myford now sits on a packing block to suit my 6" centre height lathe.
As already said, if you can't find a secondhand one that can be adapted, you could make one. If you choose to go down this route, my preference would be to use sealed ball races rather than bronze shoes to steady the workpiece.
By making your own, you may be able to produce an item that meets your needs more exactly than a proprietary item.
There have several articles in the Model Engineering press on making a steady for a particular lathe, or for some job that is too big for the "normal" device.
Pete Rimmer28/07/2018 18:15:46
1486 forum posts
105 photos
Howard makes a good point, especially for older lathes now fitted with quick change tool posts. Lathes which originally would have had a lantern toolpost hold the tool on or very near the compound's swivel centre-line so a travelling steady would would be designed to sit just to the left of centre. 4-way toolposts and more recently quick change tool posts have much more width and hold the tool much further to the left, in a position which is likely to clash with the steady.
I've had to fabricate a steel travelling steady for one of my lathes for which I have the original item because of how awkward it was to use when making leadscrews.
Spencer Ord30/07/2018 17:36:50
14 forum posts
14 photos
Thanks for the information guys.
I can make one if I can't find the original.
