Want to put a brass union in a Stainless Steel? tube
Martin King 205/07/2018 08:55:08
1129 forum posts
Hi All,
My next door neighbour has a very nice Triumph TR3A which at the moment has the front off for some work on the radiator and a general clean up of the now accessable areas.
He has a manually switched Kenlowe fan for extra cooling but wants to take this opportunity to fit a union into the stainless cooling down pipe to take a thermostat for the Kenlowe.
This part is available withe the union already done for £20 or so but we wonder if it is OK to silver solder or JB weld a suitable brass union into the existing pipe?
Seems an easy job? maybe not?
Cheers, Martin
Nick Hulme05/07/2018 09:04:22
750 forum posts
37 photos
Plumbers solder will be up to the job for car cooling systems provided the physical fit is well designed and gives adequate area, leaded or lead free.
Hopper05/07/2018 09:14:00
7881 forum posts
397 photos
I would spend the 20 quid for the correctly made fitting that you say is available. If your soldered joint leaks at some point in the future, due to vibration, age, corrosion, not quite soldered right etc, it can drain the cooling system, overheat and totally destroy your engine, costing thousands to repair.  Not worth the risk, to me. Most people don't watch the temperature gauge when they drive so this kind of thing happens more often than you might think.
Edited By Hopper on 05/07/2018 09:15:01
Brian Wood05/07/2018 09:39:12
2742 forum posts
39 photos
I would be tempted to silver solder the two together and then pressure test the joint afterwards. I don't think a soft soldered joint would be good enough.
David George 105/07/2018 09:51:59
2110 forum posts
565 photos
Silver solder will do the job just be carefull clean the joints and use good quality solder and flux.
David
mechman4805/07/2018 10:27:47
2947 forum posts
468 photos
Spend the £20; not worth the risk of engine damage should the joint fail.
​George.
Keith Hale05/07/2018 16:02:36
334 forum posts
Make sure you use a non magnetic steel to a avoid crevice corrosion.
Then use 455 silver solder and HT 5 flux.
