Ross Lloyd 1 | 22/06/2018 23:05:15 |
153 forum posts 1 photos | Hi I have a couple of regular turning tools that seem to suffer from chip evacuation problems. I noticed I was getting an awful finish during turning and a lot of noise, so I tried angling the cutter slightly in the horizontal plane, about 10 degrees nose towards the chuck. The chips seemed to flow out more smoothly. Should this be necessary? One tool is self made, and another I wrecked and reground on a grinder. I am wondering if they just both lack the correct relief or if an angle is usually needed? |
Hopper | 23/06/2018 04:55:48 |
![]() 7881 forum posts 397 photos | Do whatever works for you. There is no hard and fast rule about the angle of the tool presentation. I often swing mine around the other way a bit, so the point is trailing the leading edge. Seems to spit the chips out better. Only about 10 or 15 degrees needed. On the ohter hand, many carbide inserts are deliberately made with a point of 80 degrees or so, so that both cutting edges are angled a bit away from the face being machined, providing clearance. Presenting the cutting edge square on to the job does seem to generate long, straightish strarnds of swarf that are a pain to deal with. Angling the tool tends to curl the chips up more conveniently. Also experiment with feed rates and rpm. Different combinations affect chip generation. |
Mick B1 | 23/06/2018 07:26:30 |
2444 forum posts 139 photos | Rotating a knife tool with a cutting corner of less than a right angle slightly towards the chuck can have a couple of benefits: (i) on light finishing cuts, a small plan trail angle results in a shaving action along the edge that's nearly parallel to the work surface, giving a potentially good finish, and (ii) where a number of passes have been made to reach a size up to a shoulder, the shoulder can then be squared-off neatly by withdrawing the tool at a slowish 'reverse-facing' feed. However, there's risk that on roughing cuts the tool will be dragged deeper into the work by the forces acting on the negative angled chuckside edge. Theoretically you might overcome that by locking the crossslide, but in practice that would lose you most of the time saved by the deeper cut and introduce additional variables that would make the size achieved less certain, so not many people that I know of do it. Better to present the chuckside edge square or with a positive plan approach angle for heavier cuts. |
Neil Wyatt | 23/06/2018 11:00:30 |
![]() 19226 forum posts 749 photos 86 articles | Angling a tool gives thinner, wider chips, which, especially with HSS, can lead to freer cutting. A knife tool with just the end cut across at an angle is best set at about ten degrees to allow easy working into a corner and facing as Mick describes. Angling it the other way (or grinding across the corner), by rather more (say 20 degrees or more) creates a roughing tool that may be able to deliver deeper or faster cuts but won't cut up to a shoulder. For the best finish a rounded tip and/or small flat on the tip parallel to the work (which shoudl ideally be a bit longer than the amount of feed per revolution) will help. 'Polishing' the ground edges with a slipstone or diamond card can help too. Neil
John Reese | 24/06/2018 01:46:23 |
![]() 1071 forum posts | By varying the lead angle of your tool you get a lot of control over the evacuation of chips. I made a custom toolholder for HSS to fit my Aloris toolpost. The holder had a 12* back rake built into it. I had about 8* side clearance on the tool and a15* rake chipbreaker on the top surface. If I had the tool perpendicular to the work the chips impinged on the just machined surface and damaged the finish. I found that about 15* of lead angle eliminated the problem of chip impingement. |
SillyOldDuffer | 24/06/2018 09:32:56 |
10668 forum posts 2415 photos | Posted by Ross Lloyd 1 on 22/06/2018 23:05:15:
Hi I have a couple of regular turning tools that seem to suffer from chip evacuation problems. I noticed I was getting an awful finish during turning and a lot of noise, so I tried angling the cutter slightly in the horizontal plane, about 10 degrees nose towards the chuck. The chips seemed to flow out more smoothly. Should this be necessary? One tool is self made, and another I wrecked and reground on a grinder. I am wondering if they just both lack the correct relief or if an angle is usually needed? No, but it may not matter. I guess your grinding is a little off and - as you suggest - angling the tool provides the relief that a more accurately ground tool would have built-in. Good tip I got off the forum (forgot who, apologies) was to put an extra 10mm (or so) on top of the grinding platform so that the wheel naturally undercuts the tool at a tangent, and then grind at a horizontal angle, say 15 degrees, to provide relief. Works for me. As a tool wears, it sometimes helps to angle it to present a different part of the edge to the work. I usually resharpen instead. I'm not good at grinding (facets galore, cooked steel, and burnt fingers) and prefer carbide. Even so, about 10-20% of the time I go back to HSS, usually on small diameter work where a fine finish is needed. Dave
Edited By SillyOldDuffer on 24/06/2018 09:34:03 |
Vic | 24/06/2018 10:33:15 |
3453 forum posts 23 photos | Posted by SillyOldDuffer on 24/06/2018 09:32:56:
I'm not good at grinding (facets galore, cooked steel, and burnt fingers) and prefer carbide. Even so, about 10-20% of the time I go back to HSS, usually on small diameter work where a fine finish is needed. Dave Make yourself a Tangential tool Dave, easy to make on the mill and grinding the tool bit is simple.
John Haine | 24/06/2018 13:49:49 |
5563 forum posts 322 photos | If you are wanting repeatability when changing between tools, better to make sure any such angle is ground into the tool, not imposed by turning the toolpost. I've gone to a lot of trouble to make a very solid toolpost base that is rigidly located on the cross-slide, and the Dickson block is dowelled to it to be precisely square. All my tools are snugged into their holders and tightly clamped, so I can be sure that it goes back into exact position. Makes CNC turning and I suspect using a DRO system much more convenient. |
SillyOldDuffer | 24/06/2018 14:52:03 |
10668 forum posts 2415 photos | Posted by Ross Lloyd 1 on 22/06/2018 23:05:15:. ...I noticed I was getting an awful finish during turning and a lot of noise ...
Just another thought, that could be chatter. In addition to the relief & tool grinding mistooks already discussed, there are other causes:
Recognising these comes with experience. Don't be afraid to experiment and don't be discouraged. It's a little like learning to drive: kangaroo petrol, dings, crunching gears, over-revving, stalls, clutch abuse, right-turn terror, hitting kerbs, parallel parking, and many, many foolish misjudgements.After a bit of practice you drive better than Lewis Hamilton, or at least I think I do. Dave |
Mick B1 | 24/06/2018 15:10:00 |
2444 forum posts 139 photos | Posted by SillyOldDuffer on 24/06/2018 14:52:03:
...After a bit of practice you drive better than Lewis Hamilton, or at least I think I do. Dave And then again, Lewis Hamilton's driving is of a specialised type, and tells you little of how he'd do in the Tuesday evening rush hour on the bypass. Similarly, you'll probably find it best to suit your tools to the type of work you're going to do. Accurate repeatability isn't often required unless you're making batches of components, which hasn't often been needed in my model engineering experience. It's been more useful to me to have a versatile go-to tool I can use on a variety of materials and cutting angles, as the spectrum of both that I've encountered has tended to be broad. |
Ross Lloyd 1 | 24/06/2018 21:56:09 |
153 forum posts 1 photos | Hi guys Thought it might help if I show you the tool I am using. Its my first home brew tool, but I also am having trouble with a bought one that I reground after an encounter with some extremely hard "I found this lying about and wont be repeating that mistake anytime soon" machining experiment. Its left hand turning (and pristine) brother has no such issue though. Below is the home brew un-angled, I realise there is no radius which might help to add. There is a 7 degree relief on all appropriate faces: Edited By Ross Lloyd 1 on 24/06/2018 21:58:00 |
John Reese | 25/06/2018 08:59:25 |
![]() 1071 forum posts | That tool would be great for facing shoulders on turned work. I would expect chips leaving the tool will impinge on the just cut surface and scuff it. Rotating the toolpost 10* to 15* clockwise should cure that problem, The alternative is to grind the front face to give a front cutting edge angle of 10* to 15*. |
Andrew Johnston | 25/06/2018 10:16:29 |
![]() 7061 forum posts 719 photos | I'd agree with SoD; I suspect the noise/finish issues are nothing to do with the angle of the tool to the work. Looking at the tool in the picture I'd add a bit more top rake for low carbon steels. While I use mainly inserts on the manual lathe on the repetition lathe I exclusively use hand ground HSS. There is no way to twist the tool; the tool carousel presents the toolbit at right angles to the work come what may. I always grind a slight side relief, so to get a sharp shoulder you need to traverse and then move out from the work. Which is what you'd do anyway. Generally I don't have problems with swarf ejection or scuffed surface finishes, with one exception. That being aluminium alloys; whatever you do the swarf has a tendency to birdsnest and get trapped. That changes the surface finish from shiny to dull. A variation of sods law (not the SoD above!) means that birdsnesting and trapping always seems worst on the final cut. Andrew |
SillyOldDuffer | 25/06/2018 10:38:31 |
10668 forum posts 2415 photos | Hard to tell from your picture Ross but the tool looks high to me. Are you aware of the metal strip method for checking it? With the lathe stopped gently pinch a metal strip vertically between the tool-tip and a rod. If the top of the strip leans away when you tighten the pinch, the tool is too high. If the bottom leans away the tool is too low. Adjust by shimming until pinching doesn't move the strip in either direction; slightly low is OK. Further to Andrew's comments about SoDs, I've just had a birthday. Now I'm an old sod. Sorry about the sideways photo! Dave |
David Standing 1 | 25/06/2018 10:47:37 |
1297 forum posts 50 photos | Be careful about using that metal strip/rule method with inserts, particularly small tip radius ones, it is easy to snap the point off the insert if they are snucked up too tight against the rule, particularly if it is set low. I set all my tool centre heights with a fine point dead centre held in a parallel sleeve in the chuck.
SillyOldDuffer | 25/06/2018 11:37:08 |
10668 forum posts 2415 photos | Posted by David Standing 1 on 25/06/2018 10:47:37:
Very true. Because it's quicker I normally set tool height with a home-made height gauge. With a fingernail you can feel amazingly small differences in height between the tool tip and the flat top of the gauge. Main disadvantages are making the gauge accurately in the first place and having to move the saddle so the gauge can sit flat on the ways while offering up the tool. I made the gauge from Aluminium rod which picks up dings if you sniff at it. With hindsight mild-steel would be better. Dave |
Mick B1 | 25/06/2018 11:59:01 |
2444 forum posts 139 photos | Posted by David Standing 1 on 25/06/2018 10:47:37:
I've not found that an issue with smaller lathes like the Myford Speed 10 I used to have and the Warco WM250V I use now. Though It'd more likely be a possibility with industrial-size machines with less sensitivity in the crossslide. I've made 'L' section toolpost inserts that present a 1/4" square HSS tool at centre height with a few thou ground off the top in producing the top rake. If I have to grind the side or tip back, I might have to put a few thou of thin card or shim under the tool to bring it back up to centre, but if that's not enough I'll grind the blank back to full square section and remake the tool - that's why I prefer the 4" long blanks, 'cause you can do that several times. I check for CH with a light facing cut, making sure it cuts off any pip. Of course for work with existing axial holes, you don't generally need to be that cute. |
duncan webster | 25/06/2018 12:03:52 |
5307 forum posts 83 photos | don't get too carried away with setting centre height. The main effect of having it wrong is the front clearance changes. If you're machining something 6" diameter and you've got the tool height 1/16 too high it will reduce the front clearance by just over a degree. I'm not going to get worked up about that. Obviously for small stuff it matters more, and for facing off. There is also a very small effect on diameter, in the above example if I feed the tool in by 0.1" the actual reduction in workpiece radius is 0.10002". Again it has more effect on small work. When I worked in a machine shop many years ago, the thinnest packing available for the 4 tool turrets was 1/16", but this means you can get within 1/32" up or down |
Vic | 25/06/2018 12:20:22 |
Hopper | 25/06/2018 12:21:09 |
![]() 7881 forum posts 397 photos | Usually more critical on smaller diameters. You can get away with the tool set well below centre and it still cuts ok. But too far above centre on small diameter and the front face can rub on the job, instead of the cutting edge. Also, if there is any tool movement, as on a small flexible lathe, or an old worn one, a tool set above centre will dig into the job deeper, sometimes causing problems. A tool below centre will flex downwards and away from the job. |
