John Hinkley | 16/06/2018 11:37:56 |
![]() 1545 forum posts 484 photos | I am designing a travelling steady for my 9 x 20 lathe. It will have the capacity to support stock from 5mm to 95mm diameter and is, I think, a unique design. ( Expecting to be proven wrong ). What I need, to save me hours, if not days, of hacksawing and filing, is a ( preferably local ) laser cutting service. At one point I did have the name and address of a chap quite near me ( I'm now in Doncaster ) who did this but his contact details have got lost in the house move. The parts requiring cutting will be made from 3mm and 5mm thick mild steel plate. I will supply drawings in dxf/dwg/pdf etc as required. Can anyone make any suggestions where I might get the job done, please? Thanks, John Edited By John Hinkley on 16/06/2018 11:39:38 |
John C | 16/06/2018 11:49:48 |
273 forum posts 95 photos | This chap - in Donny.... http://www.modelengineerslaser.co.uk/ Says closed all of Jun though. John |
JasonB | 16/06/2018 12:05:10 |
![]() 25215 forum posts 3105 photos 1 articles | I've used Lasermaster a few times, just e-mail the files and it comes back in the post. |
John Hinkley | 16/06/2018 12:48:47 |
![]() 1545 forum posts 484 photos | John C and Jason, Thanks for those links. I've bookmarked both and will follow up on Monday. John |
Ian P | 16/06/2018 12:58:09 |
![]() 2747 forum posts 123 photos | I have no connection with this company, but after using several different laser cutting companies over the last 10 years have 'Microkerf' a breath of fresh air! To be honest I have only used them one time a few weeks ago but the service was exceptionally good. What I like especially is that the process is fully automatic and generates quotes within seconds of the DXF file being uploaded so one can make changes and see the effect on cost. The quote generated give several prices (for 1 off, for the requested quantity, for 25, 50, 100, and also what the parts would cost if filling a full sheet of material. As I said I only have one purchase experience but I will definitely use them again, the nine different parts I bought all cost less than the four other quotes I got Ian P
jann west | 16/06/2018 14:01:25 |
106 forum posts | If you already have a air compressor you can pick up a chinese plasma cutter on ebay for £150-ish. |
John Hinkley | 16/06/2018 14:26:10 |
![]() 1545 forum posts 484 photos | Ian P - I'll bear this company in mind, though I suspect the cost may be prohibitive unless they can tack my job onto another batch. Thanks anyway. Jann - regrettably, I had to leave my compressor in France when we moved back to the UK and I have no immediate intention to replace it. John |
Jonny Duke | 16/06/2018 16:25:24 |
10 forum posts | I use these people to cut stainless sheet to complex shapes and they do a good job for a competitive price. Yorkshire Profiles, Unit 6A Hessay Industrial Estate Hessay, York North Yorkshire, YO26 8LE Tel. 01904 737095 Fax. 01904 737096 I hope that helps, Jon |
Jonny Duke | 16/06/2018 16:28:42 |
10 forum posts | I should add: I just send them DXF or DWG files. Don't even try using a Chinese diy cutter.
Jon |
John Hinkley | 16/06/2018 18:53:06 |
![]() 1545 forum posts 484 photos | Jon, Thanks. Another lead for me to follow up. John |
John Hinkley | 06/07/2018 17:54:25 |
![]() 1545 forum posts 484 photos | Eventually finalised the design and sent files to modelengineerslaser.co.uk and lasermaster. Only Malcolm at model engineers laser replied, so he got the job - at an extraordinarily reasonable price, I might add. I expect to be picking the pieces up some time next week and will probably start a new album to document the build. Thanks to all responders. John Edited By John Hinkley on 06/07/2018 17:55:04 |
