Inverter
Rod Ashton | 09/06/2018 11:28:57 |
344 forum posts 12 photos | Hi - I have fitted an ABB MT2000 3ph. motor to my Myford. Using an ABB ACS 300 inverter. I cannot get much top speed and have very little torque. Pretty much useless . If anyone could advise. Would be most grateful.
John Rudd | 09/06/2018 12:11:57 |
1479 forum posts 1 photos | start with basics... What ac voltage in- inverter voltage out....240-240? Or 240-415 Has the motor been correctly supplied? Is it wired correctly? 415 for Star or 240 for Delta? |
Oldiron | 09/06/2018 12:27:00 |
1193 forum posts 59 photos | As JR said. You need to match the motor to the Inverter with regard to Volts Hz etc. If they are new and supposedly matched I suggest you call the supplier. regartds |
Rod Ashton | 09/06/2018 13:23:04 |
344 forum posts 12 photos | John - Bit out of my depth here as you may have gathered. Says on the inverter :- Input - 208/240V, 8.9a, 48/63 Hz. Output - 0/u1in V, 4.3a, 0/500Hz. |
David Jupp | 09/06/2018 13:55:27 |
978 forum posts 26 photos | So output voltage varies between zero and the input voltage (the unit doesn't include a transformer to step the voltage up). To match this the motor would normally be expected to be wired in Delta (3 straps wired across the terminal box, with no connection between them). Each output from the ACS300 goes to one of the 3 straps in the terminal box. And remember the Earth connection. |
KWIL | 09/06/2018 15:04:33 |
3681 forum posts 70 photos | Have youi got the Manual? http://simon-kleyn.chudov.com/Childhood-Pictures/ABB_ACS300_Users_Manual.pdf
Martin Cargill | 10/06/2018 12:12:12 |
203 forum posts | Have you tried their Technical helpline? Most invertor suppliers provide telephone technical backup for their products and their engineers are very good at guiding you through the setup for their products. |
Rod Ashton | 10/06/2018 13:28:27 |
344 forum posts 12 photos | OK folks thanks for the info. Got the manual and spoken to their helpline. It seems the consensus that I have it wired in star and not Delta. Will rectify in the morning. |
Rod Ashton | 13/06/2018 07:27:59 |
344 forum posts 12 photos | All issues resolved. Working properly now. Re-strapped from Star to Delta as you advised. Thank you gentlemen for your kind assistance. |
John Rudd | 13/06/2018 11:43:36 |
1479 forum posts 1 photos | Posted by Rod Ashton on 13/06/2018 07:27:59:
All issues resolved. Working properly now. Re-strapped from Star to Delta. Good to hear you got it sorted.... |
