Dave T | 01/06/2018 23:11:39 |
69 forum posts 1 photos | Hi All, I want to mill the above along a 4mm section of steel. The smallest cutter I've used so far is a 3mm, but was hand fed for a very short distance at maximum rpm and I was sweating all the way through (didn't break the cutter though The cutter I've got is HSS 2 flute and as I've got a powered x axis, will be using that. Can someone give me a little help on speed/feed/cut please? I've only got the one cutter but I'd like to preserve it as best I can. My machine is a Warco VMC. Thanks Dave T Edited By Dave T on 01/06/2018 23:12:05 |
JasonB | 02/06/2018 06:53:27 |
![]() 25215 forum posts 3105 photos 1 articles | 1500rpm, 0.5mm depth of cut, 100mm/min feed. Try it first hand feeding and if it is happy engage the feed |
Dave T | 02/06/2018 07:21:43 |
69 forum posts 1 photos | Thanks Jason |
Vic | 02/06/2018 10:09:46 |
3453 forum posts 23 photos | My milling chart says 2400 rpm for a 4mm cutter in mild steel. If you’ve got a VMC you should have a 2100 rpm option, that will do. I would sneak up on it and try a cut at 0.25mm first and increase slowly if it’s happy. 100mm/min feed is about right. |
Adam Mara | 02/06/2018 10:57:06 |
198 forum posts 1 photos | I have a spare 1/16" cutter ex cutting plastic on a CNC router, PM me if you are in need! I have found they may not cut plastics cleanly, but seem to cut metals OK |
Dave T | 02/06/2018 12:17:03 |
69 forum posts 1 photos | Vic, It's a 2 mm slot in 4mm material |
not done it yet | 02/06/2018 12:33:27 |
7517 forum posts 20 photos | To avoid breaking your cutter, might a slitting saw be an alternative? |
Vic | 02/06/2018 15:15:10 |
3453 forum posts 23 photos | Posted by Dave T on 02/06/2018 12:17:03:
Vic, It's a 2 mm slot in 4mm material Ah, not sure of the speed then my chart doesn’t go that small. As said though, a slitting saw may be better? |
Dave T | 02/06/2018 16:45:15 |
69 forum posts 1 photos | A slitting saw is a definite thought, thanks |
JasonB | 02/06/2018 17:07:24 |
![]() 25215 forum posts 3105 photos 1 articles | That's another reason I don't bother with charts - you are not stuffed if the size you want isn't on the chart. Anyway with no speed readout on my X3 it's all a bit finger in the wind
Thought I'd give it a go for you, used ketan's SX2.7 as that has a speed readout. Speeds and feeds as I said above but did not have a 2-flute so this is with a 3-flute, two you could up the speed and or lower the feed to keep a similar loading per tooth. Feed screw is 2mm pitch if you want to work out exact feed from my hand movements. If your cutter is a 50p Bangood special then all bets are off. Edited By JasonB on 02/06/2018 17:09:17 |
Dave T | 02/06/2018 18:14:23 |
69 forum posts 1 photos | Thanks again Jason |
Vic | 02/06/2018 18:42:22 |
3453 forum posts 23 photos | Posted by Vic on 02/06/2018 15:15:10:
Vic, It's a 2 mm slot in 4mm material Ah, not sure of the speed then my chart doesn’t go that small. As said though, a slitting saw may be better? Looking at the speed range on the VMC you’re be at it’s highest speed using a 2mm cutter and should get a nice finish. |
Dave T | 02/06/2018 19:46:28 |
69 forum posts 1 photos | Cheers Vic |
JasonB | 03/06/2018 07:29:18 |
![]() 25215 forum posts 3105 photos 1 articles | Just so happened to use the 2mm cutter last night on some cast iron, similar sort of speed but 1.0mm DOC, feed a bit of an unknown as cuts were on the R/T. Deep pockets are 4mm. |
