Raymond Sanderson 2 | 12/05/2018 00:27:17 |
![]() 450 forum posts 127 photos | Just downloaded the above MEW No 268 and reading the dial indicator article. Trevor sorry but so much is wrong in this . I am a novice but have much background. I hope many who read can assess the wrongly described situations. You mentioned Martin Cleeve's work and getting your head around it! Even my dyslexia usually only typing or writing found me re-reading one sentence 4 times on the dial engagment or disengagement?? I myself have to destress re-read often before posting even on our own blog, then I read it again. Obviuosly editing just didn't happen here.
JasonB | 12/05/2018 07:41:51 |
![]() 25215 forum posts 3105 photos 1 articles | I've altered the title so people don't confuse it with the article about using a dial indicator to set a rotary table. |
Raymond Sanderson 2 | 12/05/2018 07:49:32 |
![]() 450 forum posts 127 photos | Thanks Jason. |
fishy-steve | 12/05/2018 09:15:26 |
122 forum posts 30 photos | I haven't read the article but on quickly scanning it there is an obvious printing error on page 23. The second column has been printed in the wrong place. Steve. |
Neil Wyatt | 12/05/2018 10:41:28 |
![]() 19226 forum posts 749 photos 86 articles | My apologies, it's a text flow error as Steve has spotted. A classic example of seeing what I expected to see... because I have been through the text several times before it gets laid out I'm afraid that I must have been looking at the text and recognising the words as 'correct'. It's very hard to properly read something you have seen so many times before Neil |
I.M. OUTAHERE | 12/05/2018 11:47:36 |
1468 forum posts 3 photos | Raymond , i wonder if a a discrete message to the editor may have been more plausible ? There is very little that can be done now it has gone to print except a note on the forum and in the next issue. Other than what Steve has mentioned is ther anything else wrong with the article ? You mention that there is so much wrong with it so can you please point out everything you see wrong with it so anyone coming along who reads this thread or the article can understand what is going on . |
Raymond Sanderson 2 | 12/05/2018 14:33:17 |
![]() 450 forum posts 127 photos | Neil I know that during my time writing tech manuals and tour brochures seeing them over and over again. In checking the travel distance there is no mention of using the hand wheel to move the carriage/saddle don't forget he's trying to describe to novices those who are looking for guidance. |
Raymond Sanderson 2 | 12/05/2018 14:33:18 |
![]() 450 forum posts 127 photos | Neil I know that during my time writing tech manuals and tour brochures seeing them over and over again. In checking the travel distance there is no mention of using the hand wheel to move the carriage/saddle don't forget he's trying to describe to novices those who are looking for guidance. Edited By Raymond Sanderson 2 on 12/05/2018 14:35:49 Edited By Raymond Sanderson 2 on 12/05/2018 14:38:23 |
Hopper | 13/05/2018 07:08:51 |
![]() 7881 forum posts 397 photos | Posted by Raymond Sanderson 2 on 12/05/2018 14:33:18:
It is standard procedure when fitting a TDI to use fibre washers between the TDI body and the apron to space the TDI laterally so that when the halfnuts are engaged, one of the lines on the TDI is lined up with the reference mark. Often when the halfnuts are closed, the newly installed TDI dial is indicating in between two marks. So you add fibre washers to in effect move the TDI along the (stationary) leadscrew, which rotates the dial, which brings one of the marks on the rotating dial into line with the reference mark. I had to do this on my old Drummond after installing a new half-nut threaded insert, becuase the new threads were in a slightly different position from the originals. Also had to do it on our ML7 when it was rebuilt. I haven't received issue 268 yet so can't comment on the rest of the article. It does seem that journalism and numbers are like oil and water, though. So I don't envy anyone who has to edit an engineering magazine full of dimensioned drawings and tables of numbers! Edited By Hopper on 13/05/2018 07:11:57 |
Raymond Sanderson 2 | 13/05/2018 08:48:09 |
![]() 450 forum posts 127 photos | Hopper couldn't this be achieved by simply turning the leadscrew until it lined up with the half nuts disengaged? |
Hopper | 13/05/2018 09:25:27 |
![]() 7881 forum posts 397 photos | Posted by Raymond Sanderson 2 on 13/05/2018 08:48:09:
Hopper couldn't this be achieved by simply turning the leadscrew until it lined up with the half nuts disengaged? No. Absolutely not. That is the point. If you turn the leadscrew with the halfnuts disengaged until the TDI marks line up, if the TDI is not correctly spaced with fibre washers, when you try to close the halfnuts they will be out of mesh with the leadscrew. Then when you move the carriage, or rotate the leadscrew, that half or quarter of a thread left or right so the halfnuts can engage, the TDI dial rotates and the lines get out of line. Hard to explain in words without diagrams etc. Best go out in your shed and have a look at your lathe. In essence, the stationary leadscrew acts like a rack as the carriage is moved back and forth by the carriage handwheel and the halfnuts disengaged. But once the halfnuts are closed and the leadscrew is then rotated to move the carriage along, the teeth of the "rack" stay in the same position relative to the carriage, because the carriage moves along with the thread. Try it and observe on your lathe next time in the shed. I once had a job writing the service manuals for Collins Class submarines when they were built here in Oz. I would hate to be stranded 20,000 leagues beneath the sea and have to rely on that lot to extract myself from the fertilizer!
Edited By Hopper on 13/05/2018 09:26:18 |
not done it yet | 13/05/2018 09:28:22 |
7517 forum posts 20 photos | Think of a stationary nut with a bolt disappearing into it as it is screwed in. Does the thread disappear at exactly the same place irrespective of where the bolt may be turned. You bet it does! Simple mechanics. Same applies here. |
JasonB | 13/05/2018 10:11:03 |
![]() 25215 forum posts 3105 photos 1 articles | Isn't it easier to loosen the dial on it's spindle and just turn it so one of the marks lines up with the notch? mine is just fixed by a simple screw. Also why fibre washers which may flex, metal shim washers would surely be more rigid. |
Hopper | 13/05/2018 11:48:44 |
![]() 7881 forum posts 397 photos | Posted by JasonB on 13/05/2018 10:11:03:
Isn't it easier to loosen the dial on it's spindle and just turn it so one of the marks lines up with the notch? mine is just fixed by a simple screw. Also why fibre washers which may flex, metal shim washers would surely be more rigid. I'm thinking of Myfords here, what I'm currently familiar with. So the dial is not adjustable like that. Why fibre indeed. Just because that's what Myford seems to have used and when you nip up the nut, the TDI stays in place as the friction of the fibre washer between TDI and apron is greater than the friction of the steel nut being tightened. Maybe. Can't see any flex likely in such a low-stress application. But I'm sure steel washers would work too. |
JasonB | 13/05/2018 13:20:10 |
![]() 25215 forum posts 3105 photos 1 articles | The other problem with using shim washers would be if you had a lathe that had more than one gear for the indicator which would be a right faff having to shim it each time you needed to use the correct gear for the thread being cut. maybe the fibre washers are just standard practice on Myfords. |
Pero | 13/05/2018 13:41:29 |
193 forum posts | Certainly standard practice on my Myford which it retains its original fibre washers from new. (It's a late model ML7). I admit to not doing any thread cutting which probably explains why they have not worn! I agree with Hopper's reasoning behind the mode of adjustment adopted by Myford (and others? ). Pero
Andrew Johnston | 13/05/2018 14:30:47 |
![]() 7061 forum posts 719 photos | I don't have my copy of MEW268 yet, so can't comment specifically on the article. But I don't recall having any problems using the DTI on my lathe when screwcutting. There are definitely no shims anywhere. I suppose that if it was important to move the dial without moving anything else I'd just loosen the screw that holds the dial in place. It all sounds so complicated; I'm just glad I binned the DTI and fitted an Ainjest unit instead. I didn't actually bin the DTI; it's sitting on a shelf above the lathe along with the Dickson toolpost I never bothered to fit. Andrew |
Raymond Sanderson 2 | 13/05/2018 22:53:56 |
![]() 450 forum posts 127 photos | Ah Hopper so why is it stated in a way that fibre washers are only used IF required seems to mean No washer at all might work??
Raymond Sanderson 2 | 13/05/2018 22:55:10 |
![]() 450 forum posts 127 photos | Has anyone ever engaged the TDI first then the half nut?? |
Hopper | 14/05/2018 00:44:38 |
![]() 7881 forum posts 397 photos | Posted by Raymond Sanderson 2 on 13/05/2018 22:53:56:
So you don't have a fibre washer between the TDI body and apron, but now you are having trouble with the unit not being held tight enough? Try replacing the metal shim with a fibre washer. They slip less than a steel shim.
