Neil Lickfold | 06/05/2018 02:27:10 |
1025 forum posts 204 photos | Does anyone know where I can get the actual specs for the Dickson Quickchnage tool holders for the Myford super 7 ? I would like to know the dimensions that they use for the Vee and the area where they use a T slot cutter for the hold back clamp. I have some and can measure them, but would like to know what the actual spec is. My holders have W stamped on the inside of where the T slot cutter has passed through. Thanks for any replies, Neil Lickfold Edited By JasonB on 06/05/2018 07:54:57 |
Speedy Builder5 | 06/05/2018 07:27:50 |
2878 forum posts 248 photos | For dimensions, try this link:-
Edited By JasonB on 06/05/2018 07:55:17 |
JasonB | 06/05/2018 07:54:19 |
![]() 25215 forum posts 3105 photos 1 articles | I've not seen published drawings of the finer details just the overall sizes as above link. As yours have the original W mark probably OK to measure them. Edited By JasonB on 06/05/2018 07:58:34 |
Neil Lickfold | 06/05/2018 12:36:01 |
1025 forum posts 204 photos | Thanks Jason for making a new and better titled thread. I wonder if those who have made Dickson 00 tool holders are willing to share the dimensions that they used for making their own tool holders? Thanks, Neil Lickfold |
JohnF | 06/05/2018 16:40:26 |
![]() 1243 forum posts 202 photos | Neil here is a sketch I made from an original Myford/Dickson tool holder for another forum member last year, he was/is in France hence me using metric dimensions--if you want imperial either convert them or let me know. Hope its of use to you -- John edit PS photo in my albums in "Workshop Stuff " file Edited By JohnF on 06/05/2018 16:44:57 |
Neil Lickfold | 06/05/2018 20:38:43 |
1025 forum posts 204 photos | Thanks for that John. Neil |
Phil P | 08/12/2019 12:20:51 |
851 forum posts 206 photos | Just a quick tip for those who don't know it already. To get an accurate dimension between the "Vee's" ( the 47.98 dim in the above sketch ) Lay two bits of 1/4" diameter HSS toolsteel or something similar in each Vee, then take two measurements, one inside the round bars and another outside of them, adding the two together and dividing the result by two will give you a much more accurate dimension than trying to fit your digital verniers across the Vees. Also, the relationship between the 47.98 and the 3.7 dimensions is very important so as to make sure the clamp works in the same range as your existing toolholders. Sorry if I am teaching granny to suck eggs. Here is a parting toolholder I made for my miniature Dixon style rear toolpost on the Myford, using the method described. Here is the drawing to show what I mean. Phil Edited By Phil P on 08/12/2019 12:22:49 Edited By Phil P on 08/12/2019 12:38:22 |
Georgineer | 08/12/2019 16:33:36 |
652 forum posts 33 photos | Posted by Phil P on 08/12/2019 12:20:51:
Sorry if I am teaching granny to suck eggs... Or in the words of the classic rhyme: Teach not thy parent's mother to extract the embryonic juices of an egg by suction; That worthy lady can herself the feat enact, quite irresepective of thy kind instruction. George B. |
duncan webster | 08/12/2019 20:25:56 |
5307 forum posts 83 photos | Posted by Phil P on 08/12/2019 12:20:51:
Just a quick tip for those who don't know it already. To get an accurate dimension between the "Vee's" ( the 47.98 dim in the above sketch ) Lay two bits of 1/4" diameter HSS toolsteel or something similar in each Vee, then take two measurements, one inside the round bars and another outside of them, adding the two together and dividing the result by two will give you a much more accurate dimension than trying to fit your digital verniers across the Vees. Also, the relationship between the 47.98 and the 3.7 dimensions is very important so as to make sure the clamp works in the same range as your existing toolholders. Sorry if I am teaching granny to suck eggs. Here is a parting toolholder I made for my miniature Dixon style rear toolpost on the Myford, using the method described. Here is the drawing to show what I mean. Phil Edited By Phil P on 08/12/2019 12:22:49 Edited By Phil P on 08/12/2019 12:38:22 Neil needs to twist Phil's arm for a MEW article here, that's a lot better than holding the KitQcut blade via 2 countersunk screws |
David George 1 | 08/12/2019 21:25:36 |
![]() 2110 forum posts 565 photos | This is my drawing of toolpost stamped with a W in slot. David |
