Chris Shelton | 23/04/2018 15:02:16 |
![]() 92 forum posts 46 photos | I have an Emco V10P lathe, and need to make a carriage stop for it, but the bed ways are rather an awkward shape, I have included photo's and a tracing taken from the tailstock end of the bed in my albums. I do not possess a tilting vice or a sine bar, can anyone suggest a way of making an accurate stop for the carriage please. I do own a milling machine. |
Journeyman | 23/04/2018 15:08:39 |
![]() 1257 forum posts 264 photos | You could try something like this:- The angle of the 'V' bed on the Emco looks to be at 90deg but one side longer than the other. You may be able to modify my design a bit,. Drawing and build ***HERE*** John |
Clive Foster | 23/04/2018 15:27:17 |
3630 forum posts 128 photos | Looks as if you have a small vertical step at the bottom of the triangular guide on each side. A simple rectangular slot engaging on those vertical steps would probably give sufficient location when fixing a bed stop. Less than elegant tho'. The job would be neater if something fairly close to the triangular section above the vertical steps is cut by whatever means you have and the gap filled with metal loaded filler. Press the filled slot onto a well lubricated section of the bed to get the shape just so. Once its painted the filler won't show. One advantage of the using filler to get the right shape on the triangular part is that a fairly rough job is actually better than a super smooth machine finish as giving plenty of nooks and crannies for the filler to grab. The good metal loaded fillers tend to be moderately expensive and come in pack far to large for a single small job. JB Weld is easier and cheaper to find and works well provided the layer isn't silly thick. Advisable to put dams of some sort in if using JB Weld as it can slump. I've used duct tape and plasticine for dams in the past. Worked well enough. Johns drawings show a functional and good looking device. The bedstop for my Smart & Brown 1024 has the clamp fixings on top of the stop rather than, as is more common, below. Two bolts with square heads same size as the ones on the Dickson tool fixing bolts so the spanner is always to hand. I find this a very convenient set-up. Clive.
Edited By Clive Foster on 23/04/2018 15:33:54 |
JohnF | 23/04/2018 17:06:49 |
![]() 1243 forum posts 202 photos | Chris, As Clive says Journeyman John has posted a good basic design however I have a factory stop on my Super 11 lathe and looking at your photos of the V10P bed it looks identical so I'll go and do a drawing of my stop but please PM me with your email -- never got to grips with posting drawings on here. My drawings are done long hand no CAD etc and the only way I can send them is scan to PDF etc and email them. Cheers John |
Michael Gilligan | 23/04/2018 17:23:00 |
![]() 23121 forum posts 1360 photos | JohnF If you think your drawing might be of wider use to the community ... I could very easily convert PDF to JPG, so that you can post it here as a 'photo' [subject, of course to the forum's limits on picture size] MichaelG.
Redsetter | 23/04/2018 17:43:32 |
239 forum posts 1 photos | I made mine by sawing and filing. It did not take long. Anything wrong with that? |
Joseph Noci 1 | 23/04/2018 18:25:14 |
1323 forum posts 1431 photos | Problem with the V10P is that there is not much space between the forward V of the bed and the leadscrew below, so fancy turny handles do not fit in there. My V10p Stop is a simpler version of the one shown here - the one on my 14D ( successor to the Super 11 and Super11-CD) - The 14D item is adjustable from the top. while the bolts holding the V10P one had the bolts on the bottom. I think the top bolts will not work on the V10 though... If you need more pic of the V10P item, etc, let me know. Joe
Chris Shelton | 24/04/2018 13:25:39 |
![]() 92 forum posts 46 photos | Thank you all for the replies, I have measured the angle of the lathe bed way and unfortunately it's 85 degrees not 90 So I am going to go the sawing and filing route, was hoping to use an end mill and create the V in the stop. JohnF, I have sent a message with my email address, thank you for the reply and the offer of the drawings.
JohnF | 24/04/2018 21:52:59 |
![]() 1243 forum posts 202 photos | Hi Chris I have created an album on here with some photos and a drawing of my bed stop, the Super 11 bed is 95 deg ! I also have a pdf of the drawing but cannot get it to load !!! You also need 2 off 8mm bolts, 2 x 8mm washers and 2 springs -- see the photo's, springs are O/D 0.473" ; Wire 0.031" ; 1.500" long Edited By JohnF on 24/04/2018 21:56:06 |
Michael Gilligan | 24/04/2018 23:39:58 |
![]() 23121 forum posts 1360 photos | Posted by JohnF on 24/04/2018 21:52:59:
... I also have a pdf of the drawing but cannot get it to load !!! . We ordinary forum members can only load JPG files. ... hence my offer, yesterday. It appears, however, that the drawing you have posted is entirely adequate. MichaelG.
Redsetter | 25/04/2018 07:07:00 |
239 forum posts 1 photos | Remember it is only a G clamp, basically, and it does not have to follow the exact profile of the bedways. I found mine very useful. |
JohnF | 25/04/2018 09:53:00 |
![]() 1243 forum posts 202 photos | MichaelG Thank you for your kind offer but as you see I did it in jpg as well and it looks fine -- took a bit longer than anticipated but thats life !! John
