John Haine | 11/04/2018 06:53:57 |
5563 forum posts 322 photos | |
Thor 🇳🇴 | 11/04/2018 07:01:53 |
![]() 1766 forum posts 46 photos | Nice, but I don't have an industrial estate. Thor |
David George 1 | 11/04/2018 07:16:04 |
![]() 2110 forum posts 565 photos | 50 meters by 2 meters by 2meters is quite a size of material blank. Good job the bed dosnt move. David |
Speedy Builder5 | 11/04/2018 07:28:31 |
2878 forum posts 248 photos | Yes, we used to make small stuff like that, but then we went more industrial. CINCINNATTI MACHINE TOOLS (Birmingham UK). You knew it was a larger machine when the operator's seat ran on powered rails both up and down and along the machine. In the states, they made a machining centre where the body of a tank went in one end, and came out the other with the turret ring, drive shaft bearings, gun emplacements etc etc were all machined by several boring and milling heads. I seem to remember the total marine time was in the order of a few hours before the next body rolled in. |
Hopper | 11/04/2018 08:02:11 |
![]() 7881 forum posts 397 photos | One of them and you could machine a new workshop shed out of solid billet. Very handy. |
Circlip | 11/04/2018 09:26:53 |
1723 forum posts | Plano miller at BREL's York Carriage works (RIP) for machining DMU deck/base plate was quite a lump. Regards Ian. |
MW | 11/04/2018 10:41:13 |
![]() 2052 forum posts 56 photos | They'd need a new postcode to fit it all in. Michael W |
Colin Heseltine | 11/04/2018 12:33:39 |
744 forum posts 375 photos | BobH,
When were you at Cincinnatti? My dad worked there from age of 16 till he retired in around 1982/3. We used to have a Cincinnatti Vertical No.2 milling machine at home.
Colin |
mgnbuk | 11/04/2018 13:39:24 |
1394 forum posts 103 photos | I'm not sure that the "UK made" bit is true anymore - pretty certain they announced in the trade press that they were not going to be building their own machines here anymore & were going to be concentrating on the agencies a couple of years ago. Nigel B |
Mike | 11/04/2018 15:24:32 |
![]() 713 forum posts 6 photos | Big boys' toys - and I want one! Seriously, do they normally machine steel dry, or is the coolant turned off so that we can bee what's happening on the videos? When I saw machines not quite this big in the Mandelli factory in Piacenza in the late 1980s, they were capable of such work rates that it was refrigerated before re-use. |
mgnbuk | 11/04/2018 16:12:02 |
1394 forum posts 103 photos | Seriously, do they normally machine steel dry, Yes. IIRC one of the reasons being that the inserts need to be kept at a fairly constant temperature, so coolant needs to be a very strong flood. This is not always possible & is difficult to both guard & collect. Intermittent application of coolant to hot inserts can lead to failure due to thermal shock. Again IIRC, the idea is that most of the heat goes into the swarf, but I have regularly come across operators keeping a pair of welding gloves to hand to change tools, as the tool bodies can get hot enough to burn you. Insert drills, though, need high pressure through-tool coolant to blow the chips out of the hole - that really does go everywhere !. the Mandelli factory in Piacenza in the late 1980s, they were capable of such work rates that it was refrigerated before re-use. That may have been to keep the workpiece cool to maintain tolerances. I have seen some machines that use temperature controlled coolant circulated through the machine to keep the machine structure cool for that reason - including through hollow ballscrews via rotating unions. As Mandelli were manufacturers of quality boring machines, I would expect that they took dimensional accuracy of parts seriously. Nigel B |
Mike | 11/04/2018 16:33:44 |
![]() 713 forum posts 6 photos | Thanks, Nigel - much appreciated. My late sister was the technical translator for Mandelli in the era, and I was invited to visit the factory several times before the company got into trouble. |
