Best material for gib strips
Martin Dowing21/03/2018 17:51:26
356 forum posts
8 photos
Which material is best for gib strips of slides?
Martin
Andrew Tinsley21/03/2018 18:01:57
1817 forum posts
I have used ground steel stock and have had no problems thus far.
Andrew.
Emgee21/03/2018 18:07:07
2610 forum posts
312 photos
From similar past posts gaugeplate seems to be a good choice.
Emgee
HOWARDT21/03/2018 18:48:14
1081 forum posts
39 photos
In my working life in machine tool design taper gibs were always made of a metal softer than the ways. Hardened ways used cast iron gibs, cast iron ways used cast iron or brass gibs. Wear will occur to the softer metal over time. At a minimum use like materials for slow moving surfaces. Also consider the aspect of galling if too soft a material is used and galvanic action of dissimilar metals although this is unlikely unless water based cutting fluids are used.
John Reese21/03/2018 19:23:29
1071 forum posts
South Bend 9" and 10K lathes used steel gibs. It looks like cold rolled flat with the edges bevelled.
Martin Dowing21/03/2018 21:14:01
356 forum posts
8 photos
Many thanks for comments and opinions.
Seems that best approach is to use perhaps cast iron gibs as Howardt suggests and if for whatever reason this cannot be done some gauge plate steel will do, particularly if slide is rarely used.
Martin
mechman4823/03/2018 14:17:41
2947 forum posts
468 photos
I replaced the abortion of a gib strip on my WM250V-F compound slide soon after I bought it. I used brass plate to make new gib, as the compound slide is a casting, & not used often the different materials shouldn't be a problem ... Original gib strip... surprise
New brass gib strip ...
... works just fine, also replaced one of the adjusters with a locking screw...
George.
