How much is too much?
Jon Lawes | 06/03/2018 19:14:12 |
1078 forum posts | Can I please ask how many hard spots a casting can have before you consider it unusable? I'm trying to sort out the box bed for my Stuart 10H and I'm struggling as the file just glides over hard shiny sections and makes cutting it really difficult. I've emailed Stuart and await their response.
Cheers,
Jon. |
Chris Evans 6 | 06/03/2018 19:40:11 |
2156 forum posts | If I get "Chilled Spots" in cast iron it usually spends a night in the wood burning stove and comes out OK to machine. Even SWMBO never notices. |
roy entwistle | 06/03/2018 19:49:06 |
1716 forum posts | +1 for Chris's answer Roy |
JasonB | 06/03/2018 19:50:50 |
25215 forum posts 3105 photos 1 articles | Stuarts are usually quite good about replacing so wait to you hear back from them before cooking it. |
Jon Lawes | 06/03/2018 19:54:50 |
1078 forum posts | I don't have a wood burning stove; I guess a night on a radiator just wont cut it! |
JasonB | 06/03/2018 20:00:02 |
25215 forum posts 3105 photos 1 articles | Propane torch may just do it, that is what I usually use |
Jon Lawes | 06/03/2018 20:35:14 |
1078 forum posts | That has potential; I'll see what Stuart say. I have already taken a couple of cuts so hopefully I haven't weakend it too much. |
Jens Eirik Skogstad | 06/03/2018 21:32:53 |
400 forum posts 22 photos | See this link: http://www.homews.co.uk/page215.html Edited By Jens Eirik Skogstad on 06/03/2018 21:33:24 |
JasonB | 07/03/2018 07:23:41 |
25215 forum posts 3105 photos 1 articles | Suggesting a tipped tool will be OK for facing the surface but you are still stuffed when it comes to drilling and tapping fixing holes if the hard spot is any more than surface chill. |
Jon Lawes | 10/03/2018 17:28:57 |
1078 forum posts | They have said they will send me a replacement with no quibbling at all. I was a bit worried what their customer service would be like after my original order took some months to arrive but they seem to have good after care. |
mechman48 | 11/03/2018 00:31:12 |
2947 forum posts 468 photos | Posted by JasonB on 06/03/2018 19:50:50:
Jon Lawes | 06/04/2018 22:25:31 |
1078 forum posts | Nothing arrived yet, a month after being told they would send out a replacement. After a delay of over 6 weeks between paying for the kit and it actually turning up I guess Stuart run a fairly slow moving business. Frustrating, but I understand how low volume manufacturers work. |
IanT | 06/04/2018 23:33:06 |
2147 forum posts 222 photos | Hi Jon, I don't have a wood-burning stove either but (as I've mentioned elsewhere here recently) - I do have a garden incinerator. I compost or 'brown-bin' my soft cuttings but any 'wood' is dried out, cut or chopped up and burnt in the incinerator. I wait till I have a bright fire going (with a red-hot ash bed) and lower the part(s) in to rest on top. I then keep feeding the fire for an hour or so and then let it burn overnight with the lid on. Next day, there will still be hot ashes in the bottom and the parts will still be pretty warm but the wood fire doesn't get hot enough to damage any steel/cast iron parts. I did once try wrapping a part in kitchen foil to help keep it clean - but the foil melted. So aluminium parts/castings may get damaged doing this but wouldn't benefit from any heat treatment anyway. But for hard spots in castings and for de-stressing steel parts this seems to work OK though... I will eventually get around to trying case-hardening in it as well... Regards, IanT |
Jon Lawes | 11/04/2018 21:14:38 |
1078 forum posts | After chasing them a couple of days ago its turned up today. Looks excellent as always. |
