lee hawkins 1 | 02/03/2018 10:08:36 |
111 forum posts | Hello all Been a member on here few years now , not posted much for a long while, few years I recon, please dont feel like i only want to talk to you all, is only when I need something. I have this project, building longer rails on a chop saw, I have the rails, they are 25mm hardened steel shafts, I was thinking on using bronze bearings, but found some mild steel thick wall ferruls 50mm long 40mm od exact slide fit 25mm id Will these mild steel ferulls/bearings be ok for wear on a hardened steel shaft lee
Brian Wood | 02/03/2018 14:29:09 |
2742 forum posts 39 photos | Hello Lee, You would do better with cast iron, it is a recognised bearing material for steels hard and soft and provides it's own lubrication with the carbon content, a nice bonus to avoid grinding bearings/shaft with oil bound dust from the sawing Regards Brian |
Emgee | 02/03/2018 15:02:15 |
2610 forum posts 312 photos | Hi Lee, If the new parts allow a good sliding fit I would go with them but use a silicone spray lubricant. When they become too worn for the accuracy required you can bore them out and fit bushes to suit. Emgee |
Chris Evans 6 | 02/03/2018 15:43:48 |
![]() 2156 forum posts | Linear (spelling?) bearings are cheap and having multiple ball bearing glide really easy. Use your mild steel until they wear out, I guess it will be a long time. |
HOWARDT | 02/03/2018 16:25:13 |
1081 forum posts 39 photos | I would use proprietary bearings from either Oilite (impregnated bronze) or Igus (engineering plastics). They are both relatively cheap and obtainable. |
Nick Hulme | 02/03/2018 18:52:05 |
750 forum posts 37 photos | +1 for Linear Bearings, that's what some of the top chop saw manufacturers use, ideally you should have scraper seals to stop debris getting into the bearings. - Nick |
Emgee | 02/03/2018 20:58:39 |
2610 forum posts 312 photos | Posted by Nick Hulme on 02/03/2018 18:52:05:
I wouldn't use Silicone Oil on anything with metal to metal sliding components, it's unsuitable, Silicone Oil is great for metal to plastic and plastic to plastic though. - Nick Nick, check this out for the difference between "silicone oil" and "silicone spray lubricant" Emgee |
Bezzer | 02/03/2018 22:24:20 |
203 forum posts 16 photos | Posted by Emgee on 02/03/2018 20:58:39:
It's still Silicone though be it in oil, spray or grease form which as stated isn't really for metal to metal contact no matter what the advertising blurb says. |
Emgee | 02/03/2018 23:27:47 |
2610 forum posts 312 photos | Posted by Mick Berrisford on 02/03/2018 22:24:20:
I wouldn't use Silicone Oil on anything with metal to metal sliding components, it's unsuitable, Silicone Oil is great for metal to plastic and plastic to plastic though. - Nick Nick, check this out for the difference between "silicone oil" and "silicone spray lubricant" EmgeeIt's still Silicone though be it in oil, spray or grease form which as stated isn't really for metal to metal contact no matter what the advertising blurb says. Mick, I have used the silicone spray lubricant without problems on machine slides, after spraying it dries off and leaves a slippery surface coating on metals. Emgee |
Grindstone Cowboy | 02/03/2018 23:58:26 |
1160 forum posts 73 photos | Just to add fuel to the silicone oil 'fire', it has long been a bone of contention in airgun circles - after a lot of reading the pros and cons, I now only use moly-based grease for mine. A pretty good explanation can be found on this page **LINK** Regards, Rob |
lee hawkins 1 | 03/03/2018 08:53:06 |
111 forum posts | Thanks everyone for your ideas I am no professional engineer, but do like to do things that make a proper job, So I have opted for the oilite bronze bush, these here http://www.ashleypower.co.uk/store.php/products/amc253550-metric-plain-oilite-bush Ive been having a study of these bushes, what I have learnt , is that these bushes need to be pressed in so as to close them down to get them to fit the shaft, so when you order them at what I need 25mm id , they are a fraction over that size Is this correct ? Thanks Lee
Michael Gilligan | 03/03/2018 09:27:33 |
![]() 23121 forum posts 1360 photos | Lee, May I refer you to this thread: **LINK** http://www.model-engineer.co.uk/forums/postings.asp?th=124276 I think you should find all the Oilite information that you need. MichaelG. |
lee hawkins 1 | 03/03/2018 09:31:17 |
111 forum posts | Thanks MichaelG Will do. |
Ian S C | 03/03/2018 11:54:06 |
![]() 7468 forum posts 230 photos | I think I would try Oilite sintered iron bushes in this situation, they work the same way as the bronze Oilite bushes. Ian S C |
lee hawkins 1 | 03/03/2018 12:42:41 |
111 forum posts | Ian, Iron Bushes, only place I can find these are from companies located in India, do you know Where i could buy these in the UK or what about these https://www.bearingboys.co.uk/BU-Type-Bearings/MB2550BU-Split-Bearing-Bush-14894-p Thank lee Edited By lee hawkins 1 on 03/03/2018 12:54:22 Edited By lee hawkins 1 on 03/03/2018 13:13:22 |
Ian S C | 04/03/2018 10:03:05 |
![]() 7468 forum posts 230 photos | Sorry Lee, I'm at the other end of Earth, in NZ. Ian S C |
lee hawkins 1 | 04/03/2018 11:57:24 |
111 forum posts | Ha ha
Thanks lee
