Stirring Moose | 27/02/2018 19:24:08 |
31 forum posts 5 photos | Not had chance to do much machining of late but I'm back now, and thus have another probably daft question for you all! I currently have a pretty bog standard keyed chuck in the tailstock of my ML7 and it does a fair amount of what I need it to do. Only slight problem is that it tops out at 10mm diameter. Could really do with one that would go to 13mm (or 1/2" ). I've recently found for sale on the 'Bay a Jacob 1/2" chuck with a 2MT taper, which I believe is the correct taper for a Myford. Does anyone know if this would fit an ML7? I'm sure with a bit of investigation I could answer this question for myself, but the sale ends fairly soon so any means of short cutting the learning process would certainly help! Thanks, S.M. Edited By Stirring Moose on 27/02/2018 19:30:21 |
roy entwistle | 27/02/2018 19:28:44 |
1716 forum posts | Yes Roy |
Brian Wood | 28/02/2018 08:42:49 |
2742 forum posts 39 photos | And yes again Brian |
Martin Connelly | 28/02/2018 08:48:58 |
![]() 2549 forum posts 235 photos | If you have a 2mt taper you could also use ER collet chucks.ER32 for example will hold up to 20mm so can be used to hold milling and broaching cutters. Martin C |
JohnF | 28/02/2018 11:13:28 |
![]() 1243 forum posts 202 photos | Have a look at the keyless chucks offered by RDG I bought a16mm one and find it excellent value, all my others are Albrecht or genuine British Jacobs. They do various sizes up to 3/4” No connection to RDG other than a satisfied customer. |
Stirring Moose | 28/02/2018 22:18:58 |
31 forum posts 5 photos | Many thanks for all your help everyone. The deed is done; I won the auction so now we await the arrival of the postman to see what I've got my little graspers on... S.M. |
Speedy Builder5 | 01/03/2018 09:54:36 |
2878 forum posts 248 photos | I have 3 tailstock chucks for my Boxford, 2 Jacobs 13mm (1 for a centre drill, the other for a drill bit or tap etc) plus a smaller precision chuck 0 - 6mm as the larger Jacobs will not grip drills much smaller than 0.8mm. You can't have too many as it is quicker to change the chuck than drills etc when you have to make a quantity of the same part. |
Stirring Moose | 01/03/2018 17:11:41 |
31 forum posts 5 photos | A valid point Bob. Actually already have a second chuck in the form of a 0-6mm that came with the lathe. The addition of the 1/2" Jacobs should make a handy set. S.M. |
Phil Stevenson | 02/03/2018 10:51:41 |
90 forum posts 13 photos | Posted by JohnF on 28/02/2018 11:13:28:
Have a look at the keyless chucks offered by RDG I bought a16mm one and find it excellent value, all my others are Albrecht or genuine British Jacobs. They do various sizes up to 3/4” No connection to RDG other than a satisfied customer. Thanks for the heads up on this. I checked it out as I want one. The one I want is 0.6 - 8 with a 2MT arbour. £29.50 from RDG. On Ebay, Myford has what I guess is the same thing for £24.50 incl postage and you get it in a Myford box! |
Hopper | 02/03/2018 10:58:54 |
![]() 7881 forum posts 397 photos | Posted by Phil Stevenson on 02/03/2018 10:51:41:...
...Myford has what I guess is the same thing for £24.50 incl postage and you get it in a Myford box!
Ah well, it must be better then. |
Jon Gibbs | 02/03/2018 11:56:51 |
750 forum posts | Not a genuine Jacobs and keyed as well as more than £25 with an arbor but I've always been pleased with this chuck... I've always been hesitant with cheap keyless chucks in larger sizes auto overtightening and jamming up. Jon |
Stirring Moose | 02/03/2018 18:57:01 |
31 forum posts 5 photos | Nothing against keyless chucks in the right application - my cordless drill has one and a very useful bit of kit it is too. When it comes to the lathe, however, I must admit to coming over a bit old fashioned. Think I'd prefer to stick with keyed chucks for now. S.M. |
Jon | 02/03/2018 20:00:52 |
1001 forum posts 49 photos | Quality keyless work fine and last, what a pain keeping having to resort to picking up the key and continualyy winding to tighten a tool up, mean while 3 secs thats it. If powering taps, on reverse grab hold of the chuck works 99% of the time. An underestimated one for small stuff are Metabo, got two from 1992. On the other hand could never tolerate spending on an Albrecht, but do have many Jacobs keyed to 3/4". |
Neil Wyatt | 02/03/2018 20:02:25 |
![]() 19226 forum posts 749 photos 86 articles | I <3 my keyless chuck, definitely much nicer to use than a keyed one. Has holes for a couple of bars if overtightened. Neil |
Stirring Moose | 18/03/2018 10:46:25 |
31 forum posts 5 photos | Just realised I never finished the story. The Jacobs chuck arrived, was exactly as described, fitted straight into my lathe, has thus far done everything asked of it and we're all living happily ever after. If only everything was so simple! Thanks again to all who advised. Sure I'll be back to pester you again soon. S.M. |
