Piston not retracting
Yngvar F | 28/01/2018 16:30:21 |
75 forum posts 54 photos |
I’ve had a this 10 ton hydraulic press for maybe ten years. The return action has been getting worse and worse. From being able to push it by hand I now have to use a car jack to get the piston to retract. I have changed the fluid and bled the system. The spring inside the piston seems strong. (Tried getting it to open whithout fluid)
Any ideas on what could be wrong? |
not done it yet | 28/01/2018 17:06:37 |
7517 forum posts 20 photos | Seems like the pumping head needs some attention? Or will the piston not retract even if the supply line is released? Initially remove hydraulic pipe at the pumping head. If the piston retracts it is the head at fault, if not it could be the hydraulic pipe or the ram. Disconnect hydraulic pipe at the ram to determine if it is pipe or piston/ram. Proceed from there. |
HOWARDT | 28/01/2018 17:18:15 |
1081 forum posts 39 photos | May be the check valve on the return line. Pressure on the outlet side locks the return check valve to stop the piston moving back. On hand pumps a manual lever releases the lock pressure. |
Brian Wood | 28/01/2018 18:03:42 |
2742 forum posts 39 photos | Bent piston? |
Yngvar F | 28/01/2018 18:25:10 |
75 forum posts 54 photos | Had to leave the workshop cause the neighbours rotting house had fallen om our fibre connection. |
Samsaranda | 28/01/2018 18:36:07 |
![]() 1688 forum posts 16 photos | Could be the seal on the piston? Dave W |
FLguy | 28/01/2018 20:57:30 |
15 forum posts | Your press looks to be exactly like the Dake 10 ton press I have with the same problem..... so far no luck in correcting it but I haven't jumped into it much. I think the check valve comment may be it. Need to try that right now. |
FMES | 28/01/2018 21:16:43 |
608 forum posts 2 photos | Check the flexible hose, ten years is the normal recommended service life for flexi hoses and it could well be failing internally, causing a possible restriction. Regards Lofty |
Yngvar F | 30/01/2018 14:04:32 |
I think we have a winner. Removed the hose at the pump. Nothing At the piston. Nothing Removed check valve. Nothing Even removed the gauge.. still nothing Took the piston off the press and over to the bench. Put it down a little to hard, piston retracts and showers me and everything else in oil.
not done it yet | 30/01/2018 14:40:02 |
7517 forum posts 20 photos | Ha ha! Once diagnosed to the cylinder/piston area, you should have jacked the oil out before dismantling. When one has been sprayed with hydraulic oil, from head to toe, by a leaking hose on a trailer ram (at full lift), one remembers to take precautions with pressurised systems - even if at low pressure. |
