Eternal truths I learned from Model Engineer
A collection of wisdom gathered over many years
Martin Johnson 121/12/2017 16:22:55
320 forum posts
Did you know…………….
  • The Caledonian Railway painted all their dock shunters in lined out passenger livery.
  • Boiler fittings must (by law) be painted signal red.
  • Tufnol is the only known thermosetting thermoplastic, which is why it can be shaped in boiling water to make spring leaves.
  • All coupling rods are fluted at the back.
  • All traction engines have brass hub caps on all four wheels and a copper or brass capped chimney.
  • An exhibition judge instinctively knows more about the prototype of your model than you have found out in years of research.
  • Cast iron swarf is so abrasive it will wear out lathe beds in a matter of days. Steel swarf has no such characteristic. Emery cloth abrasive similarly loses it’s properties on contact with a lathe bed.
  • Grinding dust of micron size can be kept away from lathe beds by randomly scattered sheets of paper (never rag!).
  • The utility of a Tool & Cutter grinder can be determined by the formula:
Utility = Number of Ball Handles x Number of felt lined mahogany accessory chests
  • Tool and cutter grinders must include a 1” pitch screw. No other pitch will do.
  • All internal combustion engines start for their designers after just a few pulls on the flywheel or propellor.
  • All new locomotives designs have enough steam to remove the electric sucker after 30 seconds, full steam pressure after 5 minutes and will then do 10 laps of the track pulling 8 adults without any problems on their very first outing.
  • Scrap boxes (except mine) always contain exactly the right item to build any given project.
  • A Number 70 drill can be poked through a bit of 3/8” brass rod to make an injector cone on any old lathe.
  • The amount of coal remaining in a firebox after a half hour run can be estimated to 4 decimal places of accuracy.
Don’t take it all too seriously………..
Happy Christmas.
Andrew Johnston21/12/2017 16:31:43
7061 forum posts
719 photos
Posted by Martin Johnson 1 on 21/12/2017 16:22:55:
Did you know…………….
Bother, or words to that effect.
I only finished making a second set of traction engine hub caps in cast iron the other week, after I was told, on another forum, that gunmetal wasn't prototypical. Now I wonder who it was that pointed it out to me? sarcastic 2
Rick Kirkland 121/12/2017 17:22:33
175 forum posts
Martin Johnson 1 said [quote] all that long list of things above, . . . . Thanks for that Martin, best laugh I've had for a long time, as these days some of the stuff on this forum leaves me in deep despair, , , once again, thanks for a great laugh.
JasonB21/12/2017 17:28:32
Posted by Andrew Johnston on 21/12/2017 16:31:43:
Did you know…………….
Well it would not be me, but then again I know nothing of Burrells. You could always save the GM ones just in case you ever fancy doing a showman's conversionwink 2
Neil Wyatt21/12/2017 17:51:22
19226 forum posts
749 photos
86 articles
I fell for 1 and 2, googled number 3 and then the light finally dawned...
I assume you mean Rob Roy.
I still believe number 2 must be true
Brian H21/12/2017 18:00:07
2312 forum posts
112 photos
Hubcaps on Fowell traction engines were iron.
Neil Wyatt21/12/2017 22:14:20
19226 forum posts
749 photos
86 articles
As all ship modellers know, belaying pins were made of brass for durability
vintagengineer21/12/2017 23:41:53
469 forum posts
6 photos
I was told 40 years ago if I wanted to keep all fingers, never put your finger anywhere you wouldn't put your todger!
Chris Trice22/12/2017 02:25:57
1376 forum posts
10 photos
The chances of a fundamental cock up being discovered is inversely proportional to how close to finishing the item you are.
Rick Kirkland 122/12/2017 06:45:03
175 forum posts
Which is why I currently have a million unfinished projects on the go., just playing it safe, that's all.
jimmy b22/12/2017 06:47:32
857 forum posts
45 photos
made me laugh.
I could have added a few, but will keep that for another daylaugh
Jim
Martin Johnson 122/12/2017 08:25:50
320 forum posts
"I only finished making a second set of traction engine hub caps in cast iron the other week, after I was told, on another forum, that gunmetal wasn't prototypical. Now I wonder who it was that pointed it out to me?"
Who that man could be I just don't know! Hope you haven't really made a second set.
Glad some of my "eternal truths" have raised a laugh.
Best wishes to all for the New Year - when heads will be out of the drawings and brains and eyes will be engaged.
Martin
JimmieS22/12/2017 10:11:44
310 forum posts
Martin
Scrap box? No, lucky box as you will be very lucky if you ..........................
Jim
Andrew Johnston22/12/2017 10:16:20
7061 forum posts
719 photos
Posted by Martin Johnson 1 on 22/12/2017 08:25:50:
Now he tells me! crying 2
JasonB22/12/2017 10:22:45
Andrew, as the CI hub caps are painted could you not just have painted the GM ones? We would not have told anyone or would you have had difficulty sleeping knowing what was under the paintwink
Andrew Johnston22/12/2017 11:30:39
7061 forum posts
719 photos
Posted by JasonB on 22/12/2017 10:22:45:
.................... or would you have had difficulty sleeping knowing what was under the paint
I'd sleep alright, but would have nightmares of a rivet counter, or exhibition judge, with a magnet. Non-prototypical material, gasp, and out comes the blue pencil.
