Micro boring bars and holders
Dave Harding 121/12/2017 00:28:16
148 forum posts
4 photos
I have been trying to find a supplier of micro carbide boring bars and holders that actually quote the price of how much they cost to purchase for a project I am working on.
Can any one help.
D Hanna21/12/2017 04:33:06
45 forum posts
6 photos
Does this help on eBay. Quite a few sizes
https://m.ebay.com/sch/i.html?_from=R40&_trksid=p2056088.m570.l1313.TR1.TRC0.A0.H0.Xmicro+carbide+bo.TRS0&_nkw=micro+carbide+boring+bar
jimmy b21/12/2017 04:52:26
857 forum posts
45 photos
How small diameter and how deep have you got to go?
Jim
JasonB21/12/2017 07:48:30
Have a look at MSC they do the Iscar Piccocut mini bars and holders, about £25 a bar and £90 a holder +VAT, page 490 of online catalogue
jimmy b21/12/2017 08:02:53
857 forum posts
45 photos
I've made my own holders. Very easy on the round shank type, the "lozenge" shape type, just takes a bit more effort.
Jim
Old School21/12/2017 08:36:05
426 forum posts
40 photos
Try this company they do a range of carbide boring tools called Tiny Tools I use the 4mm diameter internal grooving tools and it's very good http://www.protool-ltd.co.uk.
Old School21/12/2017 08:57:07
426 forum posts
40 photos
Just checked the size I use its 3mm diameter and used in a 3.6mm diameter hole.
Muzzer21/12/2017 10:42:06
2904 forum posts
448 photos
You still haven't said what you mean by "small". It's all relative - ask any woman.
These ones are available down to 1mm hole dia and up to 10mm.
Korloy do a system that is available down to 8mm.
Murray
PS - Old School - thanks for the ProTools link - that's a new one on me and looks pretty interesting.
Edited By Muzzer on 21/12/2017 10:47:58
SteveI21/12/2017 15:58:22
248 forum posts
22 photos
Hi,
The question is not just what diameter bore but also what depth? Some details on that will make a suggestion much easier.
For up to 12x diameter long bores of Ø4.9mm and up I've been using some kennametal products. The inserts are proprietary so not cheap but they have sizes from a shank of 4mm,5mm, 6mm that all use the same tips. I've got the solid carbide shank bars second hand and got the tips from fg metcalfe and son. All the major vendors have their own range for this type of thing.
For below Ø4.9mm I've been using some of the Carmex "tiny tools". Same as Old School's reference supplies.
Steve
Dave Harding 123/12/2017 01:30:49
148 forum posts
4 photos
I need to make a bushing the ID is 10mm the OD is 15mm the measurements are critical. Its in stainless steel.
Paul Lousick23/12/2017 06:53:30
2276 forum posts
801 photos
HSS should be suitable for turning the bushing. Inexpensive boring bars are listed on ebay or grind your own from a piece of HSS bar.
Paul.
JasonB23/12/2017 07:31:38
If the hole is 10mm then you hardly need a micro bar, I've got a couple of bars that take CCMT inserts that will fit in there no problem.
You have not given the length but these would reach a lot further than a Micro bar would
Ian S C23/12/2017 09:56:02
7468 forum posts
230 photos
Here's my little boring bar. Piece of 1/4" sq HSS
Ian S C
Dave Harding 123/12/2017 20:53:33
148 forum posts
4 photos
The material that comes supplied for the job has a 4mm bore so I have to machine it out to 10mm ID. The outside diameter is 18 mm and that has to be reduced to 15mm. I think i am sorted now I have invested in Iscar PICCO .
I have purchased a holder and several samples of the miniature boring bars. Thanks.
Dave Harding 123/12/2017 20:55:19
148 forum posts
4 photos
The work piece is approx 12mm in length.
Muzzer23/12/2017 21:13:15
2904 forum posts
448 photos
The words "drill" and "reamer" come to mind....
Murray
Dave Harding 123/12/2017 23:57:59
148 forum posts
4 photos
The 10mm ID hole has to also be 10mm in depth with a stop at the end its not a through hole. The last 2mm retains the original 4mm bore. The whole thing has to be 12mm in length and 15mm OD. All dimensions are critical.
I think I have got it sussed now thanks for the input.
Edited By Dave Harding 1 on 23/12/2017 23:59:43
jimmy b24/12/2017 05:13:17
857 forum posts
45 photos
Good to hear its sorted.
Jim
