vintagengineer | 16/12/2017 18:25:03 |
![]() 469 forum posts 6 photos | What is the best way to weld Mazak? |
Dusty | 16/12/2017 18:30:36 |
498 forum posts 9 photos | Mazak cannot be welded, its melting point is far to low. It can be soft soldered I understand, but have never tried, or needed to myself. |
donkey | 16/12/2017 18:30:54 |
![]() 85 forum posts 5 photos | A good way to join it with strength is with a product like lumiweld. It can be done on a cooker flame. And uses a stainless rod to rid the weld puddle of oxidation. I have used it on motorcycle parts. And have never rebooked any of them. Brian |
not done it yet | 16/12/2017 18:39:55 |
7517 forum posts 20 photos | I don't believe you will weld mazak in the way welding works - ie fusing the metal by melting at the joints, often using a filler to build up the joint. Filling with a braze type of filler is possible by careful selection and careful temperature control, but brazing is not welding - just higher temperature than most soldering. Mazak is just what it is-a cheap diecasting material, often susceptible to expansion if stored in damp conditions. |
Hillclimber | 16/12/2017 18:43:23 |
![]() 215 forum posts 51 photos | http://www.rmweb.co.uk/community/index.php?/topic/8356-soldering-die-cast-metal/ |
Neil Wyatt | 16/12/2017 21:26:20 |
![]() 19226 forum posts 749 photos 86 articles | In theory it should be possible to weld it, if you can find a way to create a weld pool without the heat just melting the whole thing. You could cast up some sticks of mazac for filler metal. The trouble is it melts at such a low temperature it will be hard to get the sharp temperature gradient usually involved in welding. Perhaps a micro Oxy-propane set or a small carbon arc would provide a localised enough source of heat.
I would go with the Lumiweld suggestion, it's probably more strong and stable than Mazac. Neil |
vintagengineer | 16/12/2017 22:30:57 |
![]() 469 forum posts 6 photos | I rebuild SU and they are made from the worst possible shit imaginable! The also suffer from hydrogen embrittlement which doesn't help! But I will try lumiweld with both a flame and my tig welder. |
J Hancock | 17/12/2017 07:59:23 |
869 forum posts | Just be prepared to catch the puddle of molten Mazak, it happens quickly ! You might try one of the really low temperature 70deg alloys as a filler ? |
Hillclimber | 17/12/2017 08:33:36 |
![]() 215 forum posts 51 photos | If you are using TIG, I should have thought pulse essential. But take a look at these, although the thread on the Miller site is a little old... http://tinyurl.com/y7rl9u36 http://tinyurl.com/y846gung Finally, I'd suggest you pay attention to those zinc vapours if you try welding. They are unpleasant and dangerous. |
Ady1 | 17/12/2017 11:36:38 |
![]() 6137 forum posts 893 photos | I rebuild SU Is that SU carbs? |
vintagengineer | 17/12/2017 12:21:54 |
![]() 469 forum posts 6 photos | Posted by Ady1 on 17/12/2017 11:36:38:
Yes, sorry I think faster than i can type!
donkey | 17/12/2017 13:39:02 |
![]() 85 forum posts 5 photos | My post should have said never rebroken any of them. Seems I type too fast also.
Bri |
