petro1head | 07/12/2017 19:31:22 |
![]() 984 forum posts 207 photos | I have a Warco Mill with theiur X, Y and Z DRO The Y axis DRO is playing up. It did this once before and it was just a case of switching the DRO off and then on again. I suspect its faulty or not been fitted correctly causing it to be damamged over time. I need to check but think its still in warranty Any idea or should I just ring Warco?
Edited By petro1head on 07/12/2017 19:31:57 |
JasonB | 07/12/2017 19:38:45 |
![]() 25215 forum posts 3105 photos 1 articles | They can do that when the read head is not quite on one increment or the next, just move the table a fraction and it should stop |
fizzy | 07/12/2017 19:53:03 |
![]() 1860 forum posts 121 photos | Theres nothing wrong with your DRO...mine sometimes does exactly the same and as Jason states, it is between increments. |
petro1head | 07/12/2017 20:18:04 |
![]() 984 forum posts 207 photos | Not sure I understand I was moving the table at least 3 inches |
JasonB | 07/12/2017 20:36:17 |
![]() 25215 forum posts 3105 photos 1 articles | In that case you have a problem, thought the table was stationary Try swaping the wires between the X and Y scales as that should how if the problem is in the scale or the readout. |
petro1head | 07/12/2017 22:14:47 |
![]() 984 forum posts 207 photos | Done that and still the Y scale not reading properly
I will email Warco
Thanks |
I.M. OUTAHERE | 08/12/2017 04:30:22 |
1468 forum posts 3 photos | Hopefully it is still under warranty and they should replace it . At least you know it is not the scales so an easy change over . I read somewhere , maybe another forum of a fault with the display where it had to be reset on power up which it should never have to so maybe a proliferationation of dodgy displays coming out of china ? |
petro1head | 08/12/2017 10:28:29 |
![]() 984 forum posts 207 photos | Posted by XD 351 on 08/12/2017 04:30:22:
Hopefully it is still under warranty and they should replace it . At least you know it is not the scales so an easy change over . I read somewhere , maybe another forum of a fault with the display where it had to be reset on power up which it should never have to so maybe a proliferationation of dodgy displays coming out of china ? I think you missunderstood. The display is fine, its the scale thats faulty |
Nick Hulme | 08/12/2017 11:02:16 |
750 forum posts 37 photos | Have you checked that the read head is correctly positioned relative to the scale? There isn't a great deal of margin for error. I had a similar thing happen when a mounting bolt on which I had not used locking compound allowed the read head to slip slightly out of position. |
Dave Halford | 08/12/2017 14:38:48 |
2536 forum posts 24 photos | Could be coolant or dust got in the scale, does the seal strip work properly? |
petro1head | 08/12/2017 15:04:18 |
![]() 984 forum posts 207 photos | Nothing inside, clean. Warco have agree the unit is faulty and they will replace it However their site is showing out of stock for the 250mm scale. I wonder if a 300mm one will fit?
