Andrew Tinsley | 14/11/2017 15:09:35 |
1817 forum posts 2 photos | I will need to cut right and left handed threads on round bar and also screw cut internal right and left internal threads. I intend to use the bar to tension an assembly. I can cut normal threads (are these termed left handed threads, ignorance is bliss!), but cutting right handed threads (?) is a bit of a mystery to me. Can anyone help, or at least point me to some information, so that I can learn the technique? Thanks, Andrew. |
Martin Connelly | 14/11/2017 15:23:56 |
![]() 2549 forum posts 235 photos | Common threads are right hand threads. Left hand threads are less common. If you go to a shop and buy some nuts and bolts they are going to be right handed threads. When screw cutting in a lathe usually when the spindle and leadscrew turn the same way a right hand thread is cut. If they turn opposite ways then a left hand thread is cut. Does your lathe have a tumbler gear to reverse the leadscrew? If not then you will probably have to add an extra idler gear in the gear train to achieve the same result. Martin C |
Tim Stevens | 14/11/2017 15:26:31 |
![]() 1779 forum posts 1 photos | If you are used to cutting 'ordinary threads' (which are right handed) with a die, then the process is the same but with a special, more expensive, left-hand die. Just in case - the die is a block of hard metal, almost always a short cylinder shape, with a threaded central hole and cut-aways around the hole so that the edges can cut into the bar. These will give you the male threads. For female (inside) threads you can use a couple of taps - and again the lefthand version is less common and dearer. If you are cutting the threads in a lathe, the set-up is almost identical for internal and external threads, as the movement of the tool is geared to the mandrel to give the same pitch for each component. With the lathe rotating towards you at the top, the tool must move left for a right-hand thread, and right for a left-hand thread. Male and female threads use tools held in different ways, that is the main distinction. But unless this is an exhibition of your skill, have you thought of looking in a boat chandler's window / catalogue? This sort of threaded adjuster goes by several names, but usually has a pair of male threads of opposite hands, drawn together by a central tube with matching internal threads, turned for adjustment by a bar through a hole or a spanner on a hexagon. Too far from the coast / river / etc? Try an aero supplier, a bit more expensive and lighter, but that might be important depending on the job in hand. Cheers, Tim Edited By Tim Stevens on 14/11/2017 15:27:18 |
Journeyman | 14/11/2017 15:33:34 |
![]() 1257 forum posts 264 photos | Turnbuckles are available from ***Screwfix*** in smaller sizes, a ships chandler will probably stock larger and in stainless steel. John |
Andrew Tinsley | 14/11/2017 15:52:18 |
1817 forum posts 2 photos | Thanks gentlemen! I should have realised that the tumbler gear would reverse the leadscrew.! Not thinking straight I am afraid. Turnbuckles would be an obvious solution, and less work! Andrew. |
Juddy | 14/11/2017 16:26:22 |
![]() 131 forum posts | I've used this company before for turnbuckles, fast postage and reasonable quality for the price:
Mike | 14/11/2017 17:13:51 |
![]() 713 forum posts 6 photos | You have beaten me to it, Juddy. I was about to point out that there's a turnbuckle for tracking adjustment on my tadpole tricycle, and I believe the component is the same as used on a kart. I've followed your link, and can't believe the components are such value for money. |
Mick Henshall | 14/11/2017 17:29:18 |
![]() 562 forum posts 34 photos | Known in the RN as " bottlescrews" Mick |
Neil Wyatt | 15/11/2017 16:41:47 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Mike on 14/11/2017 17:13:51:
You have beaten me to it, Juddy. I was about to point out that there's a turnbuckle for tracking adjustment on my tadpole tricycle, and I believe the component is the same as used on a kart. I've followed your link, and can't believe the components are such value for money. How does a tadpole work the pedals? Surely it needs to metamorphose a few legs first Neil |
Mike | 15/11/2017 19:58:33 |
![]() 713 forum posts 6 photos | Thanks, Neil. I'm just like Kermit! And I really do fancy Miss Piggy! |
ega | 16/11/2017 10:33:14 |
2805 forum posts 219 photos | Better a Muppet frog at the controls of this fearsome steed than a Toad of Toad Hall! |
Andrew Tinsley | 16/11/2017 13:06:38 |
1817 forum posts 2 photos | I think I need another cognisance test! I am highly embarrassed at forgetting the tumbler gear reversed the leadscrew! Just how one can forget this is beyond me! Andrew. |
