sean logie | 02/11/2017 19:45:08 |
![]() 608 forum posts 7 photos | I'm attempting to build a vertical head for my Centec2 horizontal mill . My thoughts are ,seeing as I'm going to all this trouble I might as well try and use beefy materials because for it's size the Centec 2 is a beefy little machine . For the spindle I'm planning 80mm od steel .I need to bore this out for the spindle bearings and draw bar . My question is , The round bar I'm using will be 80mm x 250mm long is this too much for a 6" 4 jaw ,I don't have any kind of steady rest . The through bore hole isn't critical ,but the seats for the bearings are and need to be bang on .
Sean |
Michael Gilligan | 02/11/2017 20:08:14 |
![]() 23121 forum posts 1360 photos | Sean, I would say that a fixed steady of some sort is essential for success. It doesn't need to be fancy ... something fabricated from plywood should suffice. MichaelG. |
John Reese | 02/11/2017 22:32:43 |
![]() 1071 forum posts | I figured out how to do most of the machining without a steady rest. The one thing I could not figure out how to do without a steady is bore the taper. I suggest you search for a steady that fits your lathe.
Michael Gilligan | 03/11/2017 08:43:49 |
![]() 23121 forum posts 1360 photos | Posted by John Reese on 02/11/2017 22:32:43:
I figured out how to do most of the machining without a steady rest. The one thing I could not figure out how to do without a steady is bore the taper. I suggest you search for a steady that fits your lathe. . John, I think Sean's text may be a little ambiguous: I believe that it's the bearing-housing [i.e. the body of the vertical head] that he is currently wanting to machine, rather than the spindle. MichaelG. . [quote] For the spindle I'm planning 80mm od steel .I need to bore this out for the spindle bearings and draw bar . My question is , The round bar I'm using will be 80mm x 250mm long ... [/quote] Edited By Michael Gilligan on 03/11/2017 08:46:08 |
sean logie | 03/11/2017 08:56:12 |
![]() 608 forum posts 7 photos | The spindles the easy part ...well I'm hoping it will be 😁. I have nice piece of oak I could use for a steady. Sean |
larry Phelan | 03/11/2017 09:05:15 |
![]() 544 forum posts 17 photos | The only thing I have never managed to do is to set up a steady,never seem to get it right. Any advice? |
Emgee | 03/11/2017 09:21:30 |
2610 forum posts 312 photos | Larry Fit a short length of material in the chuck and turn to the exact diameter of the material to be fitted into the fixed steady, do not use a centre. Open the steady top and slacken steady to bed clamp and slide steady to the position required and clamp to bed. Emgee
John Reese | 04/11/2017 01:06:29 |
![]() 1071 forum posts | Posted by larry Phelan on 03/11/2017 09:05:15:
The only thing I have never managed to do is to set up a steady,never seem to get it right. Any advice? I usually do it by feel. I start with the jaws backed off a bit. I advance the front jaw until it touches the part. I continue to advance the jaw until there is 360 deg. contact. Next I bring up the back jar until it firmly contacts the work. Last I bring the top jaw into contact. I haven't needed to do it yet but if I had test that the alignment were perfect I would attach an indicator base to the chuck. The contact point would touch the work as far from the chuck as possible. If the steady were in perfect alignment there would be no deflection of the indicator needle as the chuck were rotated through 360 deg. If anyone has a better idea I am willing to learn. |
John Reese | 04/11/2017 01:14:34 |
![]() 1071 forum posts | Posted by Michael Gilligan on 03/11/2017 08:43:49:
I figured out how to do most of the machining without a steady rest. The one thing I could not figure out how to do without a steady is bore the taper. I suggest you search for a steady that fits your lathe. . John, I think Sean's text may be a little ambiguous: I believe that it's the bearing-housing [i.e. the body of the vertical head] that he is currently wanting to machine, rather than the spindle. MichaelG. . [quote] For the spindle I'm planning 80mm od steel .I need to bore this out for the spindle bearings and draw bar . My question is , The round bar I'm using will be 80mm x 250mm long ... [/quote] Edited By Michael Gilligan on 03/11/2017 08:46:08 Michael, Indeed I thought he meant making the spindle. If it the housing he intends to make that is a whole different problem. It would be far better if he could scrounge a piece of suitable tubing. It would be possible to do his spindle housing by clamping it to the saddle. Once there was a hole through the part the bearing seats could be done with a boring bar supported between centers. |
SillyOldDuffer | 04/11/2017 11:35:51 |
10668 forum posts 2415 photos | Posted by sean logie on 02/11/2017 19:45:08:
... The round bar I'm using will be 80mm x 250mm long is this too much for a 6" 4 jaw ...
Sean I don't remember where I got it from, possibly Sparey, but my rule of thumb maximum for unsupported work is 3 times diameter. As 3 x 80mm is 240, 250mm is high risk without a steady or a tailstock centre. Even at 3x diameter you have to be careful. I dinged my bed when a dig-in popped a 6" by 2" diameter steel rod out of the chuck. I think I was lucky not to do more damage. An unconstrained rod is a lever that multiplies the sideways force at the chuck end like a crow-bar. As my lathe has a 1500W motor the forces involved when the chuck let go were considerable. One moment I was turning, then there was a loud bang, and I remember wondering why the work had completely disappeared! Dave
Hopper | 04/11/2017 11:51:18 |
![]() 7881 forum posts 397 photos | Y'know, for less than what it will probably cost to buy the steel and bearings, you can buy a BT30 Milling head with spindle for $135 here link That's less than 100 quid. A mate of mine just bought one and it seems a good solid unit. Uses radial ball bearings rather than taper rollers but may be able to be be converted. He's busy attaching it to an old cast iron engine block to make his own milling machine using an xy table etc. Mad scientist at work! |
sean logie | 04/11/2017 12:08:32 |
![]() 608 forum posts 7 photos | Appreciate I could go and buy one Hopper , where's the fun in that 😉 I bought the mill and lathe to make things . I'm in no hurry ,I'm steady working away making other parts for mounting the head . My biggest problem is that I'm an information juncky and at this precise moment my head is buzzing 😁.One thing I'm changing is the length of the spindle . Sean |
Rainbows | 04/11/2017 12:32:09 |
658 forum posts 236 photos | What is the capacity for your 4 jaw? To copy a mini lathe headstock that has a MT3 socket and 35mm shaft. If you use a 32007X bearing with an OD of 62mm you could use 70mm stock and have a decent 4mm wall to your bearing housing. |
sean logie | 04/11/2017 12:50:21 |
![]() 608 forum posts 7 photos | Thanks Rainbows ,I have quality bearings ,the biggest has an od of 62mm and the smaller has an od of 55mm I think .I don't think 4mm is enough meat I'd rather a bit more . I can't remember off hand what the capacity of 4 jaw is ,but the max capacity of 4 jaw will dictate how long my spindle will be . This is what I'm planning ,hopefully with adjustment on the vertical axis .The collets I'll be using will be ER32 and MT2
Sean Edited By sean logie on 04/11/2017 13:05:50 Edited By sean logie on 04/11/2017 13:07:12 |
