Does anyone do a small mill but still has good travel.
Martin Turner 430/10/2017 09:51:08
54 forum posts
Hi guys, just after some advice really, just built a brick work shop down the side of my house. It's aprox 1.8m wide and 7.5m deep internal, as its only 1.8m wide I am just looking at small mills but ideally something with good travel so you could still put something like a car cyl head on. I used Bridgeports at engineering college during my apprentiship but they would be to big, I saw a Tom Senior mill on the net but don't know anything about them. Any advice will be greatly appreciated.
victor mcconville30/10/2017 10:12:05
20 forum posts
Hi Martin, i have a Chester Machine Tools 625 Mill which is very like a small Bridgeport with power feed, I have R8 Tooling in mine which is pretty robust.
Have a look at the Chester UK web site and check out their smaller mills, my work shop is 2mtrs X 8mtrs any my mill is across the 2 mtr. the travel is 250mm x 350mm
You can find Chester Machine Tools on this page over to the right and down.
Hope this helps
Vic
victor mcconville30/10/2017 10:16:00
20 forum posts
Hi again Martin, Sorry the travels are 150mm x 350mm not 250mm x 350mm.and Z travel is the same as the Bridgeport by a lifting knee.
Old age creeping up i think
Vic
JasonB30/10/2017 10:55:18
Some of the smaller mills come with two table length options which would give you say 500mm travel but you do need to be aware that the basic supporting structure is the same on either option so much like a Bridgeport with a 48" table it can sag on the overhanging end.
Andrew Johnston30/10/2017 11:08:33
7061 forum posts
719 photos
Posted by JasonB on 30/10/2017 10:55:18:
........but you do need to be aware that the basic supporting structure is the same on either option so much like a Bridgeport with a 48" table it can sag on the overhanging end.
Apparently it's worst with original, mechanical, table feed. Basically a quick change gear box hanging on the end of the table. I always park my Bridgeport with the table roughly centred, even though I have the lighter variable speed table drive.
It can be quite difficult to actually utilise the full table travel taking into account clamping requirements, so it's best to go for slightly more than you think you'll need.
Bazyle30/10/2017 12:20:48
6956 forum posts
229 photos
The equivalent of the 625 from Chester is the 626 from Warco and there is a big following on here for both and an ongoing machine specific thread if you try a search.
JasonB30/10/2017 13:11:13
I would have thought that you need something with a bigger table than 6" x 26" and only 14" of travel to skim the average 4cyl head. Not only do you need the length of the head but as they are usually done with a large dia flycutter type tool you want the tool to clear that at both ends So travel needs to be head length plus twice x half the cutter dia.
Jeff Dayman30/10/2017 15:37:23
2356 forum posts
47 photos
If planning to flycut a lot of car heads I would first do a check of the mill to be used, using an old scrap head. Do the cut as you usually would but first jury rig a dial indicator under each end of the table, and watch them during the cut at the outer extremes of table travel. The indicators should be rigidly supported from the machine base or the floor if the mill is bolted down. If table is deflecting more than a few thou during the cut, your milled head won't likely be flat enough, and you may need extra support of the table to the floor or mill base before doing non-scrap ones.
In many automotive machine shops I have been in ( since I started going to these shops in late 1960's as a kid picking up parts for my grandfather and Dad's garage, later getting my own project work done)  I noticed the mills used for flycutting/face milling blocks and heads have especially wide bases supporting almost the whole table length. This was done for maximum rigidity to assure a flat cut on decks of the large and heavy workpieces.
Edited By Jeff Dayman on 30/10/2017 15:43:15
Martin Turner 430/10/2017 16:05:30
54 forum posts
Thanks guys I will have to have a look, also are these Tom Senior mills any good?.
I guess ideally to skim something like a car cyl head you are going to need atleast 500mm plus of travel on the bed?.
I haven't really done any milling since engineering school and that was back in 1996-2001, I did have a nice Harison lathe but when I moved house it got put into storage at my uncles farm until my workshop was built, one evening some low life kids thought it would be funny to set the barn on fire that had my lathe in it, the heat was so intense all the alley gear covers and casings had melted away.
not done it yet30/10/2017 16:13:46
7517 forum posts
20 photos
I don't think I would want any large cylinder head flycut. Tramming would need to be nigh on perfect as many head gasket failures are between cylinders.
Martin Turner 430/10/2017 16:29:28
54 forum posts
I may have to settle for a smaller mill and if and when any big jobs come up just get our local machine shop to do it.
JasonB30/10/2017 17:00:29
Posted by not done it yet on 30/10/2017 16:13:46:
Don't know why not, that is how the pros do it for example this
Jeff Dayman30/10/2017 17:56:26
2356 forum posts
47 photos
Well yes the tram does have to be right. If you get a head done at any commercial automotive machine shop I'd say it will likely be done with a face mill with multiple inserts or by a heavy disk flycutter. No commercial shop will stand there all day with a 1" dia endmil going back and forth, and anyway the face mill will give a flat job with a beautiful finish dead nuts to spec if done in a heavy / ridgid enough mill.
Chris Evans 630/10/2017 20:22:09
2156 forum posts
Remember when skimming a car cylinder head it needs to be bolted down well, preferably on to a substantial plate. If you just plonk one down and skim the combustion side the camshaft bearings may not be right afterwards.
Neil Wyatt30/10/2017 20:57:34
19226 forum posts
749 photos
86 articles
Posted by Martin Turner 4 on 30/10/2017 16:05:30:
If you get one in good condition, yes, very.
Martin Turner 431/10/2017 17:56:22
54 forum posts
I have just had a look in my workshop and if I put units/workbench down the whole r/h wall I will have a gap of about 1.4M. With that in mind I would need a small mill that only has a depth of about 800mm.
I was going to put a small mill where the worktops
[img]https://image.ibb.co/fa7VQw/image.jpg[/img]
Martin Turner 431/10/2017 18:02:12
54 forum posts
And this one
Edited By JasonB on 31/10/2017 18:30:38
