Here is a list of all the postings Martin Turner 4 has made in our forums. Click on a thread name to jump to the thread.
Thread: M300 Suds Pump with inverter |
18/07/2018 21:37:37 |
Posted by john fletcher 1 on 18/07/2018 17:39:50:
Now you have your motor dismantled it might just be very easy to bring out those three extra connection to convert to Delta. Look in the stator for a lump/bump like connection, and see if you can see three thin wires going to the lump/bump. This lump/bump is often opposite end to the other output wires. Should you be lucky, then part the three wires, then carefully attach three individual insulated wires, one at a time long enough to reach the terminal box. You must find a safe route within the stator for the new wires to run, they must not rub on the rotor when its revolving. and each connection must be carefully insulated. When completed, get your friendly electrician with his 500 volt DC Megger to carry out an insulation test. There was an excellent article on "HERE" some time ago about the same thing. It can be done and many have already done it, nothing complicated, just be careful. John I have had a quick look for the star connection to see if it can be separated into 3 individual cables but at the moment I can't find it. I can only see two cores that come out the winding and go back in. We have Megger's at work, I work in the engineering department of Southampton docks. |
18/07/2018 14:48:59 |
Posted by Ian Parkin on 18/07/2018 13:29:04:
martin as has been said earlier its probably been rewired but a 415v motor should work on 240v Have you a meter to check continuity on the 3 windings? I can check it later with a meter, as the tank also needs to be repaired I may just buy a new 240v single phase setup. As it's a hobby lathe I may not even really use coolant, my old Harrison never had a working suds pump.
18/07/2018 13:19:30 |
Posted by Ian Parkin on 18/07/2018 12:24:10:
Can you spin the pump easily with your fingers if its been stood the bearings could be stuck or the impeller may be full of crud that lives in the bottom of suds tanks Strip off the pump end and see if the motor spins easily and then runs on your 240v 3 phase The pump is now fully stripped, bearings are fine. The odd thing is I only have 3 cables on my stator and as MG Electic put on there drawing you usually use 6 and wire 240 3ph into Delta. |
18/07/2018 12:11:18 |
Posted by Andrew Johnston on 18/07/2018 11:43:16:
I'm beginning to think that the coolant pump may be fudged? If it won't run in star or delta it probably is. I can't remember where I got my replacement 3-phase suds pump for the Bridgeport, as well as a single phase one for the CNC mill, but there are plenty of industrial suppliers out there. I had a bit of a to do with the single phase pump. Naturally I ordered a 240V version. When it came to wiring up it said 110V inside the connection box. So I called the supplier, who was rather rude and implied I knew nowt about electrics. I persisted and eventually they checked their stock. Turns out they'd ordered a batch of 240V units, and the units had a 240V sticker on the outside, but were really 110V units inside. Wonder how much that cost them in warranty claims! At least they apologised for being rude. Andrew When you turn the pump on you can see the shaft twitch but it wont spin up even if you help it with a spin from a screwdriver. I have sent some picture to MG Electric and they are going to ask a guy that's been there 50 years about my pump, they basically said the drawings they have show 6 cables unlike the 3 I have, my lathe was built in the 70's from memory. |
18/07/2018 11:22:45 |
Also forgot to say my lathe was stored for about 10 years and the suds tank will also need to have some small rust holes repairing. If I can't reconfigure this old pump I may just buy a new 240v single phase system, any recommendations? |
18/07/2018 11:07:13 |
Edited By Martin Turner 4 on 18/07/2018 11:07:35 |
18/07/2018 11:05:16 |
I spoke to MG Electric and they have sent me a drawing but my pump must be odd as it's only got 3 cables coming from the windings instead of 6. %5Burl=https://ibb.co/hVerMy%5D%5Bimg%5Dhttps://thumb.ibb.co/hVerMy/IMG_0797.png%5B/img%5D%5B/url%5D |
17/07/2018 21:04:17 |
I un-bolted the insulator block and it only has the 3 cables going to the stator, I did move the links to the Delta position as they were originally across the back in star but now I know there is only 3 cables it wouldn't have made any difference anyway. As the M300 is a common lathe to put in a 220v 3ph VSD has anyone else had this issue before with there suds pump. |
17/07/2018 18:43:39 |
I message Rupert Powell today as I know he has advised a few people on how to convert the M300's to VSD. It appears that the suds pump has only 3 cables coming from the stator so a Delta configuration isn't possible. Rupert sent me this video where a guy managed to get at the star point and convert the stator to a 6 wire Delta setup. https://www.youtube.com/watch?v=QY5wZytaQ0M
16/07/2018 22:57:23 |
Edited By Martin Turner 4 on 16/07/2018 22:59:45 |
16/07/2018 22:56:04 |
[url=https://ibb.co/gvyeMy][img]https://preview.ibb.co/hpyPod/IMG_0774.jpg[/img][/url] |
16/07/2018 22:48:44 |
HI guys, I have just found time to wire my Invertek VSD into my Harrison M300. Wired it as A2 to B1, B2 to C1 and C2 to A1, that'll puts it in delta. Connected one phase of the inverter to each of the new connections (C2, A1) (A2, B1) and (B2, C1) and the lathe runs fine. The suds pump is a different story, changed the links to Delta and linked it in with the 3 motor phases to try it but it's not doing anything, also the suds pump motor only has 3 cables unlike the usual 6. Any advice will be greatly appreciated. |
Thread: Warco GH750/ Chester Cub 630 any good for a hobby machine. |
27/12/2017 10:39:10 |
I ended up getting a Harrison M300 in the end, needs a clean up as it's been in storage for 8 years but atleast all the bare steel parts got oiled up before it was stored. Just need to decide if I want to run a rotary converter or convert it to a variable speed inverter setup. |
Thread: Static phase converter |
20/12/2017 20:34:57 |
Posted by David Colwill on 20/12/2017 09:23:12:
Just out of curiosity do the Transwave rotary converters give you a neutral? Regards. David. According to the guy I spoke to a Transwave yes the rotary converters give a neutral and all 3 phases. |
20/12/2017 02:48:51 |
Posted by larry Phelan on 19/12/2017 19:42:44:
I have a 10hp Transwave rotary converter \nd it runs EVERYTHING in the shop,no messing about. 12"X9" planer,4hp spindle moulder,3hp band saw,lathe,milling machine,the lot !,sometimes two or three machines at the same time. The more I read about these rotary converters I think it's the way I may go, the guy that sold me the lathe had a Transwave rotary converter, it was a shame he wanted to keep it. |
19/12/2017 19:24:20 |
Posted by norm norton on 19/12/2017 17:02:55:
We have not answered your initial question about how a static converter works. Yes, the Machine Mart chap is right in that two phases are fed, one fully and one partially if I remember, and then the third gets energised as the motor spins. The converter box contains capacitance and inductance bits to generate this and there are setting knobs to make it run 'sweetly'. It means that the converter power rating ought to match the motor reasonably well and that the motor is under extra stress when starting up. A rotary converter already has the spinning motor and therefore its three phase delivery is there all the time and more 'clean'. Edited By norm norton on 19/12/2017 17:05:07 I had a chat today with the guys at Transwave and they explained a static converter basically like you said in your post. To future proof my workshop they actually recommended a rotary converter around 5-7hp. My Warco mill hadn't had much use so that's hopefully got life left in it so will probably stay 240v. I would like a bigger compressor so if a nice 3 phase one comes up atleast I can run it if I went the rotary route.
Edited By Martin Turner 4 on 19/12/2017 19:25:43 |
18/12/2017 20:32:15 |
Thanks guys, I used a M300 when I worked at the railway and to be honest it was fine on a normal 3 phase supply and fixed motor speed. The guy that sold me the lathe used it on a Transwave rotary converter but he wanted to keep it so it wasn't put in with the deal.
18/12/2017 19:55:15 |
18/12/2017 17:31:56 |
Hi, just bought a M300 lathe and soon I will be looking for a phase converter. I have looked at the static Transwave's and also our local machine mart has there's on offer, when I spoke to there technical guy he said there static converters only have power on 2 phases and gets the other phase from the motor, is that right?, I thought my lathe would need all 3 phases. Thanks in advance |
10/12/2017 13:55:38 |
Posted by Raymond Anderson on 10/12/2017 13:14:53:
Hi Martin, was looking at the lathe [ if I have the correct ebay item ] [ by CJ Machinery ] then that is the same model as mine. The speed /feed control knobs are the original ones on the "for sale " lathe, my ones I made new a couple years back. also that is the exact type of handles that mine had [ before I fitted the cast ones ] The green appears slightly different but that could be down to the photo. so in a nut shell, that is the same machine as mine. After 16 years or so I had a look for my receipt from Warco as to the cost of my one but alas it must be long gone. I can't remember what I paid for mine, but as I said earlier it has been a superb buy That's the one, they want quite strong money for it as they think it's mint but if you compare it to the Chester 630 I listed in my first post it's not as clean as that one. I guess some dealers try there luck with a higher price but it keeps going in eBay and doesn't sell, strange it's not on the CJ web site.
