martin107 | 26/09/2017 18:05:55 |
62 forum posts 2 photos | Hi Again I have a Clarke CDP152B drill and want to use it for some light milling work, what do you recommend as a cross vice or movable bed. Martin |
jann west | 26/09/2017 18:37:43 |
106 forum posts | a real mill ... you can use a XY cross slide vice ... but drill presses are for drilling, not for milling. Jacobs chucks don't do a good job of holding milling cutters, and drill presses aren't designed for the tangential forces of milling. unless you're planning on milling softwood or something similar it's not a great idea. |
Andrew Tinsley | 26/09/2017 18:39:39 |
1817 forum posts 2 photos | Please don't even think about doing it Andrew |
martin107 | 26/09/2017 18:48:31 |
62 forum posts 2 photos | I take it it's a big NO NO then anybody got a cheap little mill they want to sell. Cheers Martin |
richardandtracy | 26/09/2017 19:24:26 |
![]() 943 forum posts 10 photos | It is a big no-no. There are several reasons.
I wouldn't even recommend routing wood with a drill press. Regards Richard.
martin107 | 26/09/2017 19:36:00 |
62 forum posts 2 photos | Many Thanks Richard most of what you have said has gone way over my head but I understand the gist of it, a big NO NO in caps. Cheers Martin |
SillyOldDuffer | 26/09/2017 20:12:59 |
10668 forum posts 2415 photos | Never mind Martin. Asking if a Bench Drill can be used as a milling machine has come up before. Many, many times! You're in good company - it's not at all obvious that it's a bad idea. You can do light milling on a lathe with a Vertical Slide (optional accessory). Didn't get on with it myself though it has a long history. In the past most amateur milling was done on a lathe and excellent results achieved. I found a proper milling machine much easier to use. Those cross vices are pretty hopeless too. It's the only tool I've ever bought that was a complete waste of money. Does anyone know different? Dave
martin107 | 26/09/2017 20:31:45 |
62 forum posts 2 photos | Cheers Dave, Ideally I would like to buy by the sounds of it a second hand warco super mini lathe (brushless motor, longer bed etc.) with a few bits and a small second hand milling machine for sub £800 is this possible Cheers Martin |
Limpet | 26/09/2017 21:39:02 |
136 forum posts 5 photos | Posted by SillyOldDuffer on 26/09/2017 20:12:59:
Couldn't agree more the only thing my cross vice does is make the drill table so heavy I can hardly lift it (old Mending floor standing drill) Lionel |
Clive Foster | 27/09/2017 00:02:50 |
3630 forum posts 128 photos | Cross vices can be OK on a pillar drill. One of the biggest of the breed, 8" size, lives on my Fredrk. Pollard 15 AY as the normal work holding device. Picked up a set of multi-vee jaws, Nu-Tool brand I think, for it which makes work holding pretty easy. Three vertical Vee grooves of different size and one horizontal in each jaw. A couple of sacrificial MFD plates with gripping battens underneath, one big, one small, do for sheet work. Often a few wood screws is the best work holding method for sheet metal. The 15 AY has a screw jack table lifter as standard so weight isn't really an issue. Extra mass of the bigger vice probably helps. Bringing it home from a Model Engineer exhibition on a motorcycle, Trident T150 V in those days I think but maybe DB32 Goldie, was um "interesting". Objectively its still a rattly latchity rubbishy old thing but it works well enough despite numerous "must give it a work over" comments during the last 25 + years. Hafta lock the slides of course for most work. All set up for fast removal if need be but can't recall the last time I shifted it. Clive. |
IanT | 27/09/2017 00:09:21 |
2147 forum posts 222 photos | Posted by SillyOldDuffer on 26/09/2017 20:12:59:
Those cross vices are pretty hopeless too. It's the only tool I've ever bought that was a complete waste of money. Does anyone know different? Dave Well, I find my 6" cross-vice quite useful Dave. It's pretty much a fixture on the table of my Warco 2B - and it's been there a few years now. I quickly realised it wasn't a 'poor mans' XY Table - simply not accurate enough - and as others have said - you couldn't mill on it even if the drill was suitable. But it is good for 'positioning' over holes without a lot of fuss and once there it locks up Ok. It does make the table heavy but the Warco has a rack on the column, so it's not a problem for me really. In fact I like it so much that, as I mentioned a few weeks back, I fitted a 3" cross-vice under my little Cowells - but had to modify the Y traverse and make some raising blocks. It simply lifts off the base if not required and I can swing the normal table back around for some things that are easier to just drill on it - but it's nice to have the choice....the packing is adjustable - very basic but it works... Regards, IanT
