UK supplier of 1mm T section parting blades
Graham Butcher24/09/2017 11:13:56
21 forum posts
Does anyone know of a supplier of 1mm 0.040" wide P1N HSS parting blades in the UK. Theses are T section with a chip breaker groove. They are available in the US but wondered if there is a UK supplier. Many thanks Graham.
Edited By Graham Butcher on 24/09/2017 11:14:52
Michael Horner24/09/2017 13:55:34
229 forum posts
63 photos
Hi Graham
Have a look at the Exccentric Engineering add on this page near the bottom.
He sells them and has a UK distributer.
Cheers Michael.
Nick_G24/09/2017 14:08:18
1808 forum posts
744 photos
The ones I have purchased from Eccentric engineering are of excellent quality but have a flat top to them without the groove Graham is requesting.
Nick
Edit :- The ones from Chronos https://www.chronos.ltd.uk/acatalog/New--Clamp-Type-Parting-Tool-s-with-Chipbreaker-Blade--5--cobalt-.html look from some of the images as if the may have a groove in them. - You could always phone them and ask.
Edited By Nick_G on 24/09/2017 14:13:19
John Rudd24/09/2017 14:23:38
1479 forum posts
Nick, blade is 2mm thick.....I have one , they are good....
New 5/16 Sq Shank Clamp Type Parting Tool with 80 mm M-35 HSS Chipbreaker Blade (Ref: 392655)
BLADE
2 mm thick x 8 mm wide x 80 mm long. M-35 HSS with 5% Cobalt
Edited By John Rudd on 24/09/2017 14:24:52
Michael Horner24/09/2017 20:03:38
229 forum posts
63 photos
Posted by Nick_G on 24/09/2017 14:08:18:
"T" Type Parting Off Blades
The premium quality blades we stock are sourced from the largest manufacturer of repetition lathe tooling in the USA.
The blades have a slight hollow grind along the top (bottom) cutting edge which assists in curling the chip for easier ejection from the cut.
The industry standard height for 1/2" "T" type parting blades is actually close to 12mm.
Please be aware that some of the cheaper "T" type blades from China and India are 12.7mm (1/2" high and will not fit the FoR inverted parting tool holder.
This is what EE's advert says
Cheers Michael.
Nick_G24/09/2017 20:15:45
1808 forum posts
744 photos
I stand corrected. smiley
Nick
sean logie25/09/2017 10:09:57
608 forum posts
7 photos
I use a dremmel to grind a light grove along the length of it .
Sean
Graham Butcher25/09/2017 21:29:16
21 forum posts
Many thanks for all the replies I shall order one from Eccentric engineering.
Graham
